reinstalling flywheel
Old Sep 17, 2002 | 04:23 PM
ponykiller's Avatar
I need to know about installing the flywheel. I removed it to have it resurfaced, but when I went to reinstall it, the little "key" got pushed out of place, so I ended up scratching it. I am purchasing a new key tomorrow, but I would like to know any tricks for getting it to stay in place when putting the flywheel on.
thanks,
Kris
Old Sep 17, 2002 | 04:46 PM
DaleClark's Avatar
RX-7 Bad Ass
It really doesn't matter if the key is scratched or anything - it doesn't matter how it looks, just as long as there's a physical hunk of something in there to keep the flywheel from freewheeling.
Anyhow, it's common after insertion/removal of the key for the slot to get a little "loose" and the key wants to walk back when you install the flywheel. I've taken a hammer and screwdriver to one edge of the key and made a small gash - that gash stuck out just a little to give the key better friction in the slot so it stays put.
The key is really not a very precision thing - if it's in there, you're golden.
Make sure the inside of the flywheel (where the e-shaft goes through) is clean and smooth - you might want to put a little engine oil on to help it install smoothly.
Dale
LongDuck
Oct 7, 2015 08:12 PM
