Lots of fuel questions.
Old Sep 17, 2002 | 02:16 PM
Jahoo88's Avatar
I am putting a TII motor in an NA. I will have a 3"dp/mp, 2.5" single, staightthru catback. Also the TID mod and FCD.
What do i need for fuel? Is a walbro enough?
My NA doesnt have the TII resistor pack, should i go with a rising rate fuel press. regulator or get the resistor pack?
An FCD gives enugh fuel for ~8psi, right? So will a rising rate fpr make it safer to run with an fcd, since it will increase pressure with boost.
Old Sep 17, 2002 | 02:21 PM
BlackRx7's Avatar
Daily Domestic Killer
Dude this question had been asked countless times, there is a search button.............
Old Sep 17, 2002 | 02:37 PM
Cheers!'s Avatar
Former Rx7 *****
I think you need the resisor pack inorder to run the injectors from the TII engine...
walbro should be fine... if you are worried about boost creep you can always pull the turbo off and port the wastegate some more... what TII engine is that? S4? or S5 TII engine?
Old Sep 17, 2002 | 03:08 PM
Jahoo88's Avatar
S4 TII engine and ecu
turbo-minivan
69
Feb 4, 2016 12:29 AM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
