All choked up...
Old Sep 16, 2002 | 12:57 PM
All choked up...
Hi all,
Newbie to the forum, looking for next steps on my '84 12A choke **** problem; it suddenly won't stay out the required amount of time from starting (or at all).
I've checked continuity on the coupler as per Haynes manual (30-odd ohms so I suppose it's ok?); if it's not the magnetic choke body where else should I start looking? The carb body or attachments perhaps?
Been reading the board for a while now, and coming from Northern Ireland where rotary ownership and support is uh, non existent; I'd appreciate all the help I can get!
Old Sep 16, 2002 | 01:04 PM
Manntis's Avatar
add to cart
Wish I could help. Mine's fuel injected.
Old Sep 16, 2002 | 01:09 PM
1st7heaven's Avatar
give the forum some time, someone will have your answer soon!
I had my choke for about...um.....2days then had a holley carb. This was back in 1987!!!
Sorry I was no help.
Old Sep 16, 2002 | 02:40 PM
diabolical1's Avatar
see if any of this helps out
https://www.rx7club.com/forum/showth...hreadid=114948
Old Sep 17, 2002 | 10:00 AM
Thanks, I'll check that out when I get home, especially the last bit about the wires to the thermostat; on the UK model (mine at least) the choke cable goes directly to the rear of the carb body and is not connected to anything else. I thought that the function of returning the choke **** was controlled purely by the magnet in the assembly, and that is why the continuity in the coupler needs to be checked. I suppose it does need to know that the engine has reached temperature though...
Hipsiguy
Jan 13, 2016 01:08 PM
