Raise Idle???
Old Sep 14, 2002 | 09:31 PM
Raise Idle???
i need to know how to raise an idle on a 94.
Old Sep 14, 2002 | 10:04 PM
duboisr's Avatar
There is a air mixture screw on the lower front of the throttle body that may rise the rpm if it needs adjustment also there is a screw and lock nut on the front linkage of the throttle body that you are not to use but if you know what you are doing it will work. It opens the primary plate . you can also adjust the stop on the wax rod cam on the back side of the throttle body
Old Sep 14, 2002 | 10:43 PM
JONSKI's Avatar
5yr member, joined 2001
https://www.rx7club.com/forum/showth...hreadid=105324
Old Sep 15, 2002 | 02:37 AM
Street King's Avatar
*** Bless Texas!
Can I ask why you need to raise idle, I thought I did, and that wasn't the problem.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
