Sponsored by: CARiD
Help me!! stumble.
Old Sep 12, 2002 | 02:06 PM
Soo Dong Baek's Avatar
Help me!! stumble.
my rx7 stumble at around 3000rpm under light acceleration.
I heard many rx7 have this 'stumble' problem. what' the reason why it stumble?
Old Sep 12, 2002 | 03:38 PM
JONSKI's Avatar
5yr member, joined 2001
If your RX-7 is a 3rd gen ('93-'95) then it can sometimes be fixed by grounding the engine.
Old Sep 12, 2002 | 04:04 PM
diabolical1's Avatar
yeah, what year?
Old Sep 13, 2002 | 01:55 AM
Originally posted by diabolical1
yeah, what year?
my rx7 is 94. I exmaine the stumbling rpm in 2nd gear. it was at around 1,800rpm, accelerating at 30mm??(I don't know exactly the boost unit below 0 bar) on Boost gauge.
in 1st gear, the stumbling rpm is at around 3,000. The acceleration depth(which I can see on the boost gauge) is exactly same with that in 1st gear.
Old Sep 13, 2002 | 02:00 AM
yes I've heard that the problem was sometimes fixed by grounding the engine.
But what is grounding? My english is so poor that I can't understand. Could you explain it by easy words?
I guess grounding means making something still.
is that right?
Old Sep 13, 2002 | 09:08 AM
JONSKI's Avatar
Grounding is when you run thick electrical wire from the negative battery terminal to another part of the car. In this case, you want to run the cable to the engine. You can get a grounding cable at an auto parts store.
Old Sep 13, 2002 | 01:29 PM
I really appreciate your help. Thank you ve~~~ry much
Old Oct 21, 2002 | 03:41 PM
Soo Dong Baek, did you have the problem fixed? Let us know. Cause there are more than just grounding lead to engine stumble at mid rpm for 3rd gen also.
Hyper4mance2k
103
Mar 29, 2022 04:51 PM
lerch32
Feb 27, 2006 07:19 PM
Dlbgirl
Dec 8, 2003 01:24 PM
Michael Filippello
Power FC Forum
19
Apr 22, 2002 09:42 PM
