Maybe my car was modded/chipped before i got it?
Old Sep 11, 2002 | 12:43 PM
I Killed Tupac's Avatar
The only performance mods i have done since i got my FD is 3" cat back exhaust, and its not a true cat back, it actually starts about 2 inches back from the cat. Anyways, i am hitting 12 psi for the first turbo, and 15 for the next. Isnt stock 10 psi?
Chipped maybe?
Old Sep 11, 2002 | 12:54 PM
paw140's Avatar
Yeah, stock is 10 psi. You better find out, because you're gonna blow your engine running at 15 psi! Actually, if it was the stock computer, you should have hit fuel cut well before you got up to 15. You should also invest in an AFR gage.
How does you catback start 2" back from the cat? That doesn't make sense to me.
Old Sep 11, 2002 | 01:03 PM
Street King's Avatar
*** Bless Texas!
Maybe your cats were gutted and you just don't know? That's what it seems like.
Old Sep 11, 2002 | 01:41 PM
rynberg's Avatar
sounds like your wastegate is not opening
Old Sep 12, 2002 | 03:19 PM
well,l i poped the kick panel off today to look at the ECU. I cant tell if the ECU itself has been opened, but it looks like the wires have been re-taped at some point in time. Is there a piggy back chip in there maybe? What should i look for as far as wastegate not opening? There doesnt seam to be any vacuum leaks or anything. Any suggestions?
Monsterbox
Jul 29, 2022 10:48 PM
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
