NA vs. TII fuel tank
Old Sep 11, 2002 | 06:14 AM
Poppinrex7's Avatar
are the tanks the same in 86-88 or are they different depths.?
thanks
mark
Old Sep 11, 2002 | 05:23 PM
Dak's Avatar
Dak
Information Regurgitator
I believe the are the same except for the fuel pump itself.But I'm not sure.
Old Sep 11, 2002 | 06:21 PM
Aaron Cake's Avatar
Engine, Not Motor
The tanks are the same, the fuel pump is not.
Old Sep 11, 2002 | 09:05 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
And, the screw holes line up for either fuel pump. This is not the case as it relates to a S4 vs S5 gas tank.
(I did this retro-fit just to see if I could. I was beyond easy)
Screw holes are different. So, if you look to retro-fit a S5 gas tank, you'll want to grab the S5 fuel pump also not only because of the different screw hole alignment, but because the S5 tank is deeper. A S4 fuel pump wouldn't reach deep enough to take advantage of the extra 2 gallon capacity.
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
