Tools
Old Jul 24, 2001 | 02:37 PM
LDL's Avatar
LDL
Newbie
Tools
Just got my 94 a couple weeks ago - 70K miles, stock. Thought I should toss in a few tools just in case (as much as will fit in one of the storage bins).
Is there anything on the car that's not metric?
Any special tools or parts I should be sure to include?
Any special tools I'll need if I decide to start tweaking it?
Old Jul 24, 2001 | 02:54 PM
fluxen's Avatar
8, 10, 12, 14, 17, 19mm sockets with ratchet. no special tools I can think of...Those will loosen/tighten almost everything on the car. Nope, there's no standard stuff stock, it's all metric.
Old Jul 24, 2001 | 03:23 PM
martini's Avatar
Dont forget the duct tape, JB weld, and Fix-a-flat..
Old Jul 24, 2001 | 04:25 PM
ejmack1's Avatar
Lawn Ornament
superglue
Old Jul 24, 2001 | 04:26 PM
f2racer's Avatar
Regarding the Fix-a-flat, I wouldn't use that sh*t... After applying, tires are basically no good. I'd put the spare on and get the tire repaired (plugged)...
Old Jul 31, 2001 | 10:57 PM
f2racer's Avatar
Make sure you get a good set of metric sockets and wrenches. Most are relatively small (10 and 12mm), larger 19, 22, 23mm are used for the oil drain plug and diff drain/fill plugs. Also a good 3/8"of stubby flex ratchet is a good investment. The engine compartment is quite cramped and I've had to use these on a number of occasions. Gotta thank Bruce for this idea!
Also getting a large (=> 12") and small (=< 8") groove joint pliers will help you in removing the nasty large clamps on which lead to the intake.
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
jdmbrendan
Oct 1, 2015 01:29 AM
josef 91 vert
14
Sep 17, 2015 09:22 PM
