alternator removal
Old Sep 10, 2002 | 05:07 PM
Rx-7$4$me's Avatar
alternator removal
I got the belt off the alternator, but I cant get it off still, it seems like theres a bolt from the back holding it in from the back left right next to the rats nest... everything else comes out, it just like pivits in this area and wont come out.? how do IGet it out?
Steve
Old Sep 10, 2002 | 05:43 PM
DK's Avatar
DK
40k worth of fail
There are two bolts ... one is the obvious one to the upper right when you're facing it that is the belt tension adjustment. There's another quite long bolt (depth of the alternator +) that it pivots on to the lower left side of it. Pay attention to the housing, it's impossible not to see. If you took that one out and it still won't come out then you just need to pull harder ... it fits there pretty snugly.
Old Sep 10, 2002 | 07:57 PM
apneablue's Avatar
Those were the only two bolts I removed to get it off too...Was pretty easy...I ended up moving the presure chamber to make it a bit easier to work, other than that it just came right out...the toughest part for me was getting the belt off and back on...
Old Sep 10, 2002 | 11:08 PM
paw140's Avatar
Mine was pretty hard to get off after removing those bolts. The first time I had to pry it up with a screwdriver (CAREFULLY!). I also had to take out a vac line that was in the way of the left side of the alternator coming straight up.
Old Sep 10, 2002 | 11:37 PM
spooledUP7's Avatar
There and back again
It is a pain in the ***. You need to rock it back and fourth while lifting it out.
Old Sep 10, 2002 | 11:42 PM
turbojeff's Avatar
Do it right, do it once
I usually loosen the black bracket that the tension adjuster is mounted on. It makes it much easier to get on and off. One nut is right by the PS pump and the other is a long bolt that goes through the waterpump.
Jeff
Old Sep 11, 2002 | 12:05 AM
Rx-7$4$me's Avatar
heh, yeah I went hardcore on this bitch. I took a crowbar, placed a lil wood between it and the alternator and popped that ****** right off
Stevo
Thanks for the help every1
Old Dec 25, 2003 | 04:07 PM
widebody2's Avatar
addicted to lounge
I've only replaced one alternator in my life and that was on my ultima. It was the biggest PITA ever to get that thing back on. Is it a real pain in the rx7 as well or not that bad? I would only be removing to get polished...it still works fine. Also can I take the outer casing off of it and get it back on?
Old Dec 25, 2003 | 04:31 PM
paw140's Avatar
It's not that hard. Pretty easy, actually.
Old Dec 25, 2003 | 08:47 PM
JONSKI's Avatar
5yr member, joined 2001
I must have cranked that thing twenty times with no success on my first try. I shot some PB Blaster on it and that f*cker came of on the second crank.
Old Dec 26, 2003 | 02:38 AM
widebody2's Avatar
addicted to lounge
can I take it apart without too much trouble so I can just send the outer shell to get polished or is that not going to happen? I don't want to even mess with it if I can't take the shell off. Thanks
Old Mar 26, 2006 | 11:53 PM
dabigesii's Avatar
Back to basics
Sorry to bring back from the dead but I can't even get the damn belt off the car. I tried the tensioner but I still couldn't get it off. I'm going to try again tomorrow. Any suggestions would be greatly appreciated.
Old Mar 26, 2006 | 11:59 PM
nashman69g's Avatar
Boost Addict
where in met are u I'm in old jefferson if u need a hand...
did you loosen the air pump?
Old Mar 27, 2006 | 12:59 AM
dabigesii's Avatar
Back to basics
I'm by transcontinental and vets. I didn't try loosening the airpump. I'll try this tomorrow and see what happens.
Old Mar 27, 2006 | 01:03 AM
nashman69g's Avatar
Boost Addict
cool, Check you PM!
Marshall
Old Mar 27, 2006 | 01:18 AM
KaiFD3S's Avatar
SINFUL7
wow, did is such a old thread
Old Mar 27, 2006 | 01:21 AM
nashman69g's Avatar
Boost Addict
well at least he search like he is supposed to instead of creating another thread!
Old Mar 27, 2006 | 06:07 AM
Sgtblue's Avatar
Urban Combat Vet
The tension adjustment for the airpump is directly underneath it. Nearly impossible to see if you've got the stock airbox. I think you'll have to remove it to reach the bolt.
Old Mar 27, 2006 | 09:38 AM
dgeesaman's Avatar
Yep, especially if it's your first time attempting it.
I need to loosen the airpump AND drop the alternator adjustment to remove that belt. I remove the airbox too. Quite the PITA.
Dave
The1Sun
Sep 15, 2015 04:45 PM
