wonky idle when cold
Old Sep 9, 2002 | 10:10 PM
omochi's Avatar
fd-withdrawal
Question wonky idle when cold
when my car is cold, and i take her out and at a stop when in 1st, why do my revs fluctuate from 1.1-1.3k or so? itl'l just bounce and it sonuds like i'm revving my car
this is only when COLD tho..
TIA
Old Sep 9, 2002 | 11:00 PM
dre_2ooo's Avatar
yeah right, i bet you dont even own an RX-7.
Old Sep 9, 2002 | 11:02 PM
Mephis's Avatar
lol your cluth is shot , or your vaccum hose is off , if your spider vaccum hose is off , dont even try 2 fix it take it to a shop unless ya like connect the dots lol
Old Sep 10, 2002 | 01:17 AM
NRA T2's Avatar
I had same problem today, and fixed today with timing, could be a vaccume leak though.
Old Sep 10, 2002 | 01:37 AM
silverrotor's Avatar
I had the same problem awile back. I verified that my TPS was not set right. After that I had no problems that you are having. You may want to check It out IMO.
Old Sep 10, 2002 | 07:05 PM
omochi's Avatar
fd-withdrawal
wtf is up with that comment ?
Old Sep 10, 2002 | 07:07 PM
omochi's Avatar
fd-withdrawal
thanks, i'll have to go check it out.
Old Sep 10, 2002 | 11:22 PM
You may want to check this one out. http://home.rmci.net/panther/tps.htm Jeff Is the man. I also zeroed Into a tee my TPS by using the 1 volt method aswell. Be sure to do this when your engine Is off and the Ignition on "On". What the hell, Hailers Is the man too.
Old Sep 11, 2002 | 02:03 PM
rx7sam's Avatar
Also when u turn ur AC on, the car revs...sounds cool though.
mikedscpt
22
Oct 28, 2015 03:04 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
Monsterbox
Sep 11, 2015 03:29 PM
RotaryBobby
Sep 10, 2015 01:33 PM
The1Sun
Sep 7, 2015 10:21 PM
