rear end problem
Old Sep 8, 2002 | 07:36 PM
2ndGen.rocket's Avatar
Ho's and Cadillac Doors
rear end problem
ok, There is something wrong with the rear end of my car. I have new shocks and springs back there, so that cant be it. Its an 86 GXL, and whenever i hit a bump, or stop hard, there is a thump at the rear passenger side. It seems to take bumps really hard back there, and its loud. this also seems like it causes the car to hop, if i hit a series of dips in the road under acceleration or something. I dont know if its a wheel bearing, I tried moving the wheels up and down and they are on there solid, so i have no idea. Any help would be appreciated.
Old Sep 8, 2002 | 08:02 PM
CNYRX7tech's Avatar
New parts do fail, never rule them out. " test don't guess" If you need help let me know and I will come check out your rx7 for you.
Old Sep 8, 2002 | 08:58 PM
twiztedjeckel's Avatar
take off your tyre flies. i know i know they match the neon but still. they will make a differance.
Old Sep 8, 2002 | 11:02 PM
good one, but i dont have tire flies.
The springs are Racing Beat springs, about 4 months old, and the shocks are Tockico Illuminas
Old Sep 9, 2002 | 12:28 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
This is probably the common.......
Broker front Diff mount.
Do a search, much discussion on how to replace these. Many will say you need to drop the rear sub-frame. But, actually, all you need to do is tilt the drivers side. Unless you do either, you can't get to the two 17MM mounting bolts.
Afterward, be sure and get your rear toe re-aligned.
Old Sep 9, 2002 | 10:42 AM
catch me if you can's Avatar
maybe you should get some to match the neon. your car would be slammin then G. go out and track down some real race cars like integra's and civic's with wings. best of luck to ya getting that problem fixed though.
Th0m4s
Feb 26, 2019 02:04 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
