Sponsored by: CARiD
Boost?
Old Sep 8, 2002 | 06:41 PM
DiaperBoy's Avatar
Question Boost?
Ok Ok Ok.... how the hell are somepeople getting upwards of 30psi (2bar) of boost out of there RX-7's.
I've run C-16 i've got the ignition down i'm getting a good A/F but i keep blowing corner seals....and that's only at 25psi. When i take it apart i have good burn....no hot spots and my plugs are ok.
Any help would be ....helpful
Old Sep 8, 2002 | 07:57 PM
JONSKI's Avatar
5yr member, joined 2001
Ask the 3rd gen forum.
Old Sep 9, 2002 | 12:35 AM
diabolical1's Avatar
what kind of apex seals are you using?
Old Sep 9, 2002 | 10:43 AM
DiaperBoy's Avatar
Lightbulb seals...........
3mm from mazdatrix...is it true that there are 1 piece seals available in Japan. I read it in my new Option Mag!
if so how do i get them?
Old Sep 9, 2002 | 10:49 AM
as far as i know there are 1 piece seals available here. check with Mazdatrix (and a few other notable rotary shops) and see which seals they recommend for your setup and boost goals.
Old Sep 9, 2002 | 10:50 AM
also, try posting in the Gen III forum - i'm sure someone else has had to have gone through this before
Old Sep 10, 2002 | 06:22 PM
NRA T2's Avatar
I have 3mm 1 pieces I got them from a mazda performance garage (WA) same $$ as 2mm
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
