FRONT Squeeky Brakes...PLEASE PLEASE HELP!!!
Old Sep 7, 2002 | 08:16 PM
xjackhx's Avatar
ok, i bought my 85 GS 3 months ago and it had very meety padds on it, but they queeled like a pig. So I replaced them and they still squeek bad even with the silicone stuff. Are there shims that are supposed to be used and how in the heck does that anti-rattle spring go in(please give a detailed description if possible)...THANK YOU SO MUCH...also the calipers are working fine and the rotors and bearing are breand new....Again thank you very much.....Jack 85 GS
Old Sep 7, 2002 | 08:20 PM
diabolical1's Avatar
what type pad are you using? metallic, semi-metallic or organic?
try cleaning them well with brake cleaner, but if you're using semi-metallic or metallic pads, they are more prone to squeaking than the regular organic crap!
Old Sep 7, 2002 | 08:23 PM
Manntis's Avatar
add to cart
New brake pads often squeak until they 'settle in'. It's normal.
Old Sep 8, 2002 | 04:29 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
my brakes squeek all the time. They have about 1000 miles on them. On occasion, at low speeds (15 or lower) i get a grinding sound, that I can also feel through the pedal (its not really harse, I have SS lines so I feel everything that goes through the brake)
Old Sep 8, 2002 | 06:49 PM
Mr. ImportGuy's Avatar
Looking for Another RX7
My breaks squeek so bad at low speeds its painful. I have comp. break pads though. heh.
Old Sep 8, 2002 | 07:36 PM
Acuspeed's Avatar
Did you have the rotors turned when you put the new pads in?
If not, did you take some fine grit sandpaper and, in a swirling motion, take off the glaze from the rotors?
If you didn't do either of those things, I would suggest you pop the wheels off again, take a good look at the rotors, and if they need turned, take them to a local brake and muffler shop or machine shop and have them cut.
If they don't look like they need turned, take the sandpaper (I used 120 grit on my PGT, but that was really a little on the rough side -- I would suggest something finer than that really) and, in a circular (swirling/non-direction) motion, take the glaze off the rotors. That will assist the pads in bedding in quicker.
Also, take a look at the back of the box the pads came in if you still have it. Some will tell you how to bed the pads in (for example, the Hawk SP's that I got for my PGT described a procedure to follow, and after performing it, they worked pretty well).
Old Sep 8, 2002 | 09:08 PM
rx7passion's Avatar
get some straight up carbon race pads, they will never squeel i swear! most pads you can buy from local parts store like raybestest pads will squeek no matter what. if it still squeels just get a louder exhaust system or a loud *** fuel pump
Jutta_J
Mar 25, 2017 11:24 PM
mazdaverx713b
19
Aug 29, 2015 12:30 PM
