thermostat install?
Old Sep 7, 2002 | 06:57 PM
Eep's Avatar
Eep
brap
thermostat install?
I did a search for it and didnt find any howto or anything, is this something I should be trying myself? I heard from a few poeple that it takes about an hour and its pretty easy.. so does anyone have any steps/pictures? hehe
thanks
nick
Old Sep 7, 2002 | 07:14 PM
jspecracer7's Avatar
1JZ powered
go to the filler neck. 3 10mm bolts are holding it in place. If something's in your way so that you can't get to any of the bolts, move it. Pull out old thermostat. Put in new one. It can be held in place with silicone sealant. Installation is in reverse.
Old Sep 7, 2002 | 11:37 PM
Eep's Avatar
Eep
brap
installed it, was really easy and didnt take long at all, car is running alot better now, also what should the water temp be normally?
thanks
nick
Old Sep 8, 2002 | 01:43 AM
Tom93R1's Avatar
gross polluter
Anywhere from 85C on the low side to 110C on the high depending on ambient temps and driving style. If you are getting above 110C then it is probably a good idea to turn the heat on full blast to cool off a bit.
Old Sep 8, 2002 | 03:10 AM
1JZ powered
thanks
nick
According to what measuring device? With the PFC, I noticed that it was always reading higher than my defi h20 gauge. But pretty much, what tom93R1 said...
If you have a PFC, fans come on at 100 and 105 FYI..
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
vmerino
Sep 5, 2015 11:26 AM
