overheating prioblems
Old Sep 6, 2002 | 08:59 PM
Eep's Avatar
Eep
brap
A week ago my car just started getting hotter and hotter over the days, I though it was just because the weather because it started getting really hot out, but one of the days my radiator(stock) just started leaking very bad, so I figure Why not upgrade it...So I got a pwr one from rx7store, they got it too me fast too , installed fine, but for some reason, the car still gets very very hot, I can put around in first and it'll get up to 125°c and I have no clue whats up with it...there is plenty of water/coolant, any ideas at all?
thanks
nick
Old Sep 6, 2002 | 10:14 PM
Fritz Flynn's Avatar
All out Track Freak!
eep,
a couple of things come to mind 1- thermostat easy fix 2-engine seals big trouble. whatever it is you better find out quick cause 125 c is way to hot
good luck
Old Sep 6, 2002 | 10:37 PM
rxshun7's Avatar
I agree. Definitely check the thermostat, its a very easy fix. I hope that this is the prob cause it would suck if the second scenario were true.
Old Sep 6, 2002 | 10:53 PM
Eep's Avatar
Eep
brap
sorry, I got my rx7 in jan, still learning alot about them... thermostat doesnt just check the temp? I read the 125 off the power fc..
thanks
nick
Old Sep 6, 2002 | 11:05 PM
eep,
i bet its your thermostat. i have one for sale if interested let me know. its also the the 175 degree variety so it opens up a little sooner than the oem. lots of people drill small holes on either side to allow for constant/faster flow especially in hotter climates or if racing etc...with temps that high i would wait until you fix the problem before continuing to drive around.
again good luck and if you want a deal on a thermostat let me know
Fritz
Old Sep 6, 2002 | 11:18 PM
Tom93R1's Avatar
gross polluter
thanks
nick
Thermostat doesn't read temps at all. It is a temperature sensative valve. After the water temp gets to a certain point (around 180F in the FD) the valve opens up allowing water to circulate through the cooling sustem. It is located right behind the water pump, takes about an hour to replace and costs I think $12 from Mazda.
Old Sep 6, 2002 | 11:29 PM
artguy's Avatar
WTB** Very Low Miles 94-95
motors typically fail at about 115+ celcius.
side seals and o rings...bye bye.
DO NOT drive it or heat it up...you will be replacing the engine if you do...rebuilding it at least.
one time is all it takes....and you are actually damaging the seals each time you heat it up like that. IMHO.
dont drive it...dont drive it...dont drive it.
I freak out if mine hits 100....but then again Ive lost two motors in three years due to heat.
j
Old Sep 6, 2002 | 11:32 PM
johnchabin's Avatar
It's cheap to replace and you don't know when it was replaced last (if ever).
Good opportunity to replace you coolant as well...
Old Sep 6, 2002 | 11:35 PM
Eep's Avatar
Eep
brap
Thank you all for all the help, I'll replace it.
JoesFC
Oct 5, 2015 08:10 AM
Devon Murray
Sep 25, 2015 09:41 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
erevos
Sep 15, 2015 09:19 AM
