pulley install problems (pics inside)
Old Sep 6, 2002 | 12:15 PM
Mikey's Avatar
1) can't torque water pump...it just turns. i can't tighten the alt belt to hold it either (that is in problem #2). what are some other options?
2) i can't get the alternator belt as tight as it needs to be. the tensioner bolt is maxed out. did you guys dremil a bigger hole at the top of the bracket?
3) water pump pulley is rubbing on radiator hose clamp. anybody else had this problem? will it go away after i get the pump properly torqued down?
4) #4 isn't a problem...i just wanted to show you my engine w/out the a/c!
Old Sep 6, 2002 | 12:24 PM
amp's Avatar
amp
old yella
have indigo complete pulley kit as well....
Number one...
Use an air rachet...or use a sears oil filter rubber wrench to hold it in place while torquing
Number two....
Make sure who have the right size belt...
Number three....
Dont fret....use an adjustable hose clamp (screw tension)...
they are thinner than the stock clamp
Old Sep 6, 2002 | 12:27 PM
amp's Avatar
amp
old yella
also noticing on the first pic on number four...
that the PS/Main belt looks loose
Old Sep 6, 2002 | 12:31 PM
Mikey's Avatar
thanks...yeah...it isn't tight at all...i just slipped it over the ps. i didn't think about the oil filter wrench that would work perfect!
Old Sep 6, 2002 | 12:35 PM
amp's Avatar
amp
old yella
kiss that nice red finish on that WP pulley goodbye...
where it meets the belt that is...not the face
Old Sep 6, 2002 | 03:26 PM
R Xplicit's Avatar
a hint for the main belt, take it to a belt shop and let them look at it. you have the same issue that i did, and i simply bought a smaller one, and tightened it up......
louis
Old Sep 6, 2002 | 04:47 PM
DamonB's Avatar
Re: have indigo complete pulley kit as well....
Wonderful idea, I must remember that one.
Old Sep 6, 2002 | 05:40 PM
reboot's Avatar
i spent more on tires...
Monsterbox
Jul 29, 2022 10:48 PM
sherff
Feb 24, 2019 12:09 PM
alphawolff
Nov 17, 2015 05:57 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
