can anyone port the TB?
Old Sep 5, 2002 | 04:27 PM
tweaked's Avatar
I want to make the throttle body ports larger. I know there are companies that will do this. does anyone know who does it well on the FCs?
Or I am pretty compitent with porting heads, but I have never done a TB anyonw know how? what is involved?
Old Sep 5, 2002 | 04:44 PM
SLOWT2's Avatar
From: new hampshire, middleton(a town so small we have no conveince stores)
just use the trusty old dremel and some cut off disks and a few grind stones, if you want to get real fancy when your done go over it with a polish bit, take no time at all
Old Sep 5, 2002 | 05:22 PM
Funklord's Avatar
http://www.teamfc3s.org/store/produc...products_id=38
Old Sep 5, 2002 | 05:40 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I'm hopefully sending one down to BDC soon. (above link). he does the TB mod for you aswell.
I don't think there is any need for bigger butterfies. BDC put down almost 500hp on the stock one. he hasn't dynoed with a ported one yet. but he says it's much better.
Old Sep 5, 2002 | 05:50 PM
duboisr's Avatar
When you say ports are you wonting to bore the ports and put in bigger throttle plates .if yes and if you could you would not be asking, Garfinkle has bored them and made the plates keeping the area ratios the same.He had one bored by a pro shop and they screwed it up ,the linkage had to be redone which Gar was able to do. If you have it done be sure the shop is good. If you are good do it your self, garfinkle s was better than the pros,
Old Sep 6, 2002 | 04:22 PM
tweaked's Avatar
That is what I want. I want to bore the S*^t out o fit and put in the largest butterflies possible.
who is garfinkle?
iamsisyphus
Sep 27, 2015 01:42 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
