Sponsored by: CARiD
RPM's - Crank or Rotors?
Old Sep 5, 2002 | 03:50 PM
djb's Avatar
djb
Probably a dumb question, but, are the RPM's registered on the tach the crankshaft or the rotors?
What is the ratio of rotor revolutions to crank revolutions?
Thanks.
Old Sep 5, 2002 | 09:24 PM
peejay's Avatar
Old [Sch|F]ool
crankshaft.
the rotors rotate at 1/3rd the speed of the eccentric shaft.
Old Sep 7, 2002 | 03:14 AM
duboisr's Avatar
the rpm is the crank speed . The crank to rotor gear is three to one . That is controled by the stationary gear and the rotor gear
Old Sep 7, 2002 | 04:59 AM
maxcooper's Avatar
WWFSMD
Eccentric, baby! The rotary has no crankshaft. But the info is right -- tach reads main shaft speed, rotors turn at 1/3 the indicated speed.
-Max
Old Sep 8, 2002 | 01:52 AM
Project84's Avatar
Open up! Search Warrant!
Old Sep 8, 2002 | 09:23 PM
93redFD's Avatar
what is the tech word for the shaft in the rotary??? So is it 3 shaft revolution is 1 rpm??? or is it 2 shaft revolutions per rpm??
Old Sep 9, 2002 | 12:12 AM
duboisr's Avatar
1rpm is the e-shaft or the crank turning one complete revolution in one minute. 1000 rpm== the e-shaft turning 1000 revolutions in one minute . in one e shaft revolution the rotor has moved 1/3 of a revolution. Ok
Old Sep 9, 2002 | 10:13 AM
djb's Avatar
djb
Thanks, fellas.
djb
Old Sep 9, 2002 | 09:03 PM
93redFD's Avatar
ok no I understand, thanks
Old Sep 9, 2002 | 09:51 PM
Project84's Avatar
At 6000 rpms, the rotors are moving at 200rpms
Old Sep 10, 2002 | 12:13 AM
duboisr's Avatar
How do you get 200 rpm for the rotors at 6000 rpm shaft speed. now I am stupid
Old Sep 10, 2002 | 01:29 AM
maxcooper's Avatar
WWFSMD
6000 RPM eccentric speed (as shown on the tach) = 2000 RPM rotor speed. The rotors turn at 1/3 the eccentric shaft RPM.
-Max
Old Sep 10, 2002 | 11:36 AM
Jeff20B's Avatar
Lapping = Fapping
Yeah, 9k RPM eccentric shaft speed means the rotors are only moving at 3k RPM. Not bad!
Old Sep 11, 2002 | 02:37 AM
Project84's Avatar
typo-
Old Oct 22, 2003 | 08:54 AM
abflug-t78's Avatar
do you guys know if the tach will still read the crank angle sensor with the egi fuse?
im doing a compression test and my readings are 7.5, 7.5, 0.0. the rpm on the gauge show 999. also it does the same thing on both rotors. when i crank the car, the tach dosnt bounce. it acts like its not counting the revolutions. do you know how to check for bad sensors or what the problem might be.
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
