does the mooing pipe need filtration??
Old Sep 4, 2002 | 09:16 PM
Pumped's Avatar
I could just leave the mooing hose blowing into the atmosphere can't I... or is there a benifit if I shove a breather on it??
Old Sep 4, 2002 | 09:21 PM
P'cola FD's Avatar
Hamado things my way!
People use the filter to try to quite it down, but it is actually blowing air out, not sucking in. So you need no filter.
Old Sep 5, 2002 | 01:01 PM
rxrotary2_7's Avatar
plug it up.
do a search, it has been discused before.
Old Sep 5, 2002 | 02:50 PM
Mahjik's Avatar
Mr. Links
Originally posted by rxrotary2_7
plug it up.
Actually, if you are using the air pump, then you don't want to plug it up. I'll post some info from maxpesce (hope you don't mind maxpesce):
maxpesce wrote
That hose is the bypass air hose from the AIR CONTROL VALVE (ACV) that regulates the amount of secondary air injected into the Exhaust Ports and Catalytic converter. When air injection is required the ACV valve opens and the Air Pump (AP) is turned ON (buy the clutch engaging) when less air than the total output of the AP is required the ACV cycles rapidly open/closed and the extra air is vented out the bypass tube (this produces the mooing sound) Throttling the air this way is MUCH easier on the AP, pullies & belt than cycling the clutch rapidly to control the airflow. plugging that tube will cause extra loading on the airpump, pullies and belt, and excessive pressure on the ACV. Much the same effect as removing the BOV would have on the TURBO.
Old Sep 5, 2002 | 06:04 PM
maxpesce's Avatar
Ex fd *****
Mahjik:
Thanks for reposting
- saved me from retyping!
cto_2
19
May 8, 2018 08:15 AM
Andrew7dg
Aug 6, 2017 01:41 PM
airjordan223
24
Oct 4, 2015 04:42 PM
