so what exactly happens during limp mode?
Old Sep 3, 2002 | 01:57 PM
ka8legend's Avatar
does it cut off fuel or spark and at what load & rpm? Also does it go into limp mode only when the mop goes bad? I got error code 12 and 17(narrow & wide range tps) which I think is non-limping, or is it?
Old Sep 3, 2002 | 02:06 PM
DaleClark's Avatar
RX-7 Bad Ass
Yeah, I think you will be in limp mode to some extent. Car might be down on power. It won't hurt anything driving like that, but you may suffer fuel economy and the like.
Is your TPS bad/misadjusted/do you know?
Dale
Old Sep 3, 2002 | 02:48 PM
ka8legend's Avatar
No, the car has a silky smooth idle @ 800 after adjusting the tps using the light method. But I read a thread from early this year in which RETed said that the wide-range could have "holes" in the circuit that can lead to high rpm hesistation. My car hits "fuel cut" at 6k rpm, in any gear except idle. Limp mode is more like around 4k rpm?
Old Sep 3, 2002 | 03:13 PM
DaleClark's Avatar
RX-7 Bad Ass
You need to do a full-range test on both TPS's - the resistance may be jumping around at high throttle openings, flagging an error code.
I wouldn't worry about what RPM it occurs at - if you're getting a TPS code, test the TPS and replace if necessary. Then go from there.
Dale
Old Sep 3, 2002 | 03:37 PM
SonicRaT's Avatar
Super Raterhater
that or your error code is stored, and you can try to clear it after you've adjusted it, just a thought
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
Jmolina0163
19
Sep 25, 2015 06:06 PM
befarrer
Sep 22, 2015 09:33 AM
Clacor
Sep 11, 2015 08:36 PM
