high idle... bac? or other cause?
Old Sep 2, 2002 | 10:22 PM
Spawn VII's Avatar
well guess what? i have that bouncing 1400-1600 rpm problem... i checked the bac... the resistance is 0.02 ohms...? would that have caused the high idle problem? if so, can i just cap off the bac and unplug it?
(kinda in a hurry to get it running again... i will take the bac off when i get a chance to, since i dun have p/s and a/c anymore)
Old Sep 3, 2002 | 01:48 AM
Spawn VII's Avatar
^bumpity bump bump
Old Sep 3, 2002 | 02:03 AM
SonicRaT's Avatar
Super Raterhater
Not really any need to take it off, just take it off and clean it out with some carb-cleaner, then hook it up to 12 volts and listen for a click and verify that it opens, then put it back on. Could also be a faulty cold start with a non-adjusted TPS.
Old Sep 3, 2002 | 02:07 AM
Spawn VII's Avatar
btw... did the tb mod, and adjusted the tps already (to my best knowledge and skill)
Old Sep 3, 2002 | 02:21 AM
SonicRaT's Avatar
Super Raterhater
then it's definatly not coldstart related Clean the BAC, then if it still idles the same, adjust the TPS again using a digital multimeter and reading the ohms, if that doesn't do it, check for vacuum leaks
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
Einheri
Oct 7, 2015 12:23 PM
