Does a 88-91 turboII engine drop into a 87
Old Sep 2, 2002 | 08:03 PM
I Dream I Drive's Avatar
Newbie
i am about to buy a 87 and all i want to know is if it will just drop in... and if it doesn't how hard is it to make it fit?
Old Sep 2, 2002 | 08:09 PM
Scott 89t2's Avatar
SOLD THE RX-7!
no, not worth it. try to find an 87-88 engine.
everything off the 87 engine would have to be swaped onto the 89 one. (manifolds, injectors, front cover, OMP ect) and everything on the 87 car would still be used. the AFM, boost sensor etc.
Old Sep 4, 2002 | 12:02 AM
allstyle's Avatar
If your talking about dropping a 89+ TII motor in an 87 TII you will be fine. No problem at all as far as installation. The thing is you will have to use premix in your gas (which I recommend to everyone) to lubricate the apex seals inside the motor. I have an 88 with a 91 motor pushin 319 rwhp and still runnin strong.
Old Sep 4, 2002 | 12:29 AM
FC Drifter's Avatar
Damaged Little F*cker
you have to swap front cover, intake manifold & TB, water pump, i think thats it. its been a while since i did my swap. my 89+ jspec runs fine, and i dont have to premix since i swapped the front cover for the mech. OMP. if you can find a good wiring harness and ECU for the 89+ T2 it would drop right in youd just have to run the new harness & ECU. itd be easier id think, but more expensive.
Kyo
Apr 13, 2019 09:24 AM
Microtech
30
Apr 23, 2016 06:37 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
82streetracer
Aug 23, 2015 09:28 AM
