Timing Adjustment
Old Sep 2, 2002 | 05:12 PM
wallin's Avatar
Timing Adjustment
I know how to adjust the timing but which way is which. I am running way to rich.
Old Sep 2, 2002 | 05:31 PM
deadRX7Conv's Avatar
Opinions are like........
Why are you running rich?
Turn CAS clockwise to advance timing.
Old Sep 2, 2002 | 05:36 PM
Ni5mo180SX's Avatar
White Comet
Use a timing gun. Make sure the engines warmed up. Hook up the timing light lead to the L1 wire. Then check to make sure the yellow mark on the pulley is aligned with the timing light. If it isnt use the crank angle sensor to make small adjustments. I believe twisting clockwise is going to advance the timing.
smikels
Rtek Forum
May 12, 2016 12:34 AM
alphawolff
Nov 17, 2015 05:57 PM
incubuseva
14
Sep 3, 2015 12:37 PM
