Oil filler neck stuck! Help!!!
Old Sep 2, 2002 | 03:22 PM
Manolis_D's Avatar
Unhappy Oil filler neck stuck! Help!!!
I'm all ready to put my new rebuilt motor into my car, and I can't get the oil filler neck out of the old intermediate housing, let alone back into the new motor . How do you get that damned thing out of there?! I've tried liquid wrench, broke a screwdriver, tried to twist it with a strap wrench (it slips)... ?!
Help!
Thanks!!!
Andrew
Old Sep 2, 2002 | 03:33 PM
Scalliwag's Avatar
WingmaN
If you have a small propane torch try heat the housing where the neck goes into it. Try not to heat the neck up though. The object is to expand the housing some. I have seen some that were so seized you could not get one out.
Be sure to try to tap neck out as quickly as possible once you heat the cast.
Old Sep 2, 2002 | 03:41 PM
billzrx7's Avatar
give some swift taps up with a hammer, its how i got mine out. nothin huge as to bend or break it but enuff to get it movin.
Old Sep 2, 2002 | 09:08 PM
Scalliwag's Avatar
WingmaN
If you really get in a bind on this and can't come up with one I will pull one out for $5 plus shipping. It's too big a pain in the buttocks not to at least charge something, but I have probably 10 plates so one ought to come out easy enough for me.
rotor_veux
Sep 3, 2015 07:10 PM
