Injector Sizes?
Old Sep 1, 2002 | 06:36 AM
Injector Sizes?
Can you help? i am in the Uk and i dont know how to convert your lb system into the cc if you get what i mean?
I will explane, I have been looking on E-Bay at Injectors etc and noticed that the US ones all say (for example) 30lb Injectors where as the Uk etc call them 550cc injectors. My problem is i dont know how to convert them to CC can and one enlighten me?
Thanks
Old Sep 3, 2002 | 05:45 PM
Or is it just that diffrent makes use diffrent methods?
Old Sep 4, 2002 | 11:31 AM
TYSON's Avatar
WTF is wrong with it now?
I typed a nice long conversion for you that got erased by the problems over the weekend. Basically it came down to an injector that flows 1000cc/min of petroleum is the same as 87 lbs/hr.
I think Lbs/hr is a bad way to rate injectors because different fuels have different densities, whereas I believe in injector must be rated to flow a certain volume. The density of the fuel would change with temperature, etc., anyway.
Old Sep 4, 2002 | 03:51 PM
So how do i convert CC to LB?
Or has anyone got a conversion chart?
Old Sep 4, 2002 | 09:27 PM
coop's Avatar
Like tyson said one is in volume (cc/min) and the other is in weight (lb/hr). The density (mass/volume) of the gas can yield the weight, then you would need to determine/find the weight of your gas per cc. That will give you the conversion.
-D
Old Sep 5, 2002 | 07:52 AM
TYSON's Avatar
To do 550 cc injectors for gasoline, multiply 87 by .55. 1600 cc is 87 multiplied by 1.6, etc.
Old Sep 5, 2002 | 08:13 AM
87GTR's Avatar
30lb injectors are 315cc
160# are 1680cc
Old Sep 5, 2002 | 06:22 PM
Dragon's Avatar
20B N/A Wide Body FC3S
Take the lbhr size x 10.5 to get cc's
Take the cc size / 10.5 to get lbhr's
very simple..
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
