Revs bouncing?
Old Aug 31, 2002 | 10:37 AM
LLman's Avatar
Lucky owner
Unhappy Revs bouncing?
Hi! my 87 N/A developed recently a problem.
When my car is warming up revs bouncing up&down when I press clutch then it idles normal. Also when driving (already with a warm engine) when I lift off the gas then the engine brakes so heavily that it feels like i hit the brakes.
Help
Old Aug 31, 2002 | 01:33 PM
Josepi's Avatar
Despise Enmity
Adjust your throttle position sensor. Also check it for correct function ala the FSM.
Old Aug 31, 2002 | 01:50 PM
LLman's Avatar
Lucky owner
Been there done that. Did not helped.
Old Aug 31, 2002 | 02:23 PM
AggieDave's Avatar
are you getting noise from your pilot or throw out bearing?
dave
87 TII (Series V Conversion)
Old Sep 19, 2002 | 09:37 PM
DSM
my '90 GTU does the same thing, i have adjusted the idle, got new spark plugs, and doubled checked the vacume hoses, what should i do next?? why is my baby doing this??
Old Oct 2, 2002 | 03:37 PM
darkwaveboi's Avatar
Need donor car in Fairfax
i believe my pilot bearing is making sounds..it squeeks at low rpms when engaging the clutch
Prediict
32
Nov 18, 2015 08:41 AM
LongDuck
Oct 7, 2015 08:12 PM
Rotafuzz
Sep 30, 2015 09:55 AM
dexter snoek
Sep 29, 2015 09:18 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
