attempted mod
Old Aug 31, 2002 | 03:14 AM
upfucd's Avatar
attempted mod
well today i completed the throttle body mod as outlined at fc3s-pro.com
i also attempted to remove the cold start thermowax assembly but couldn't for the life of me remove the screw holding the spring arm and fast-idle cam pivit, the tutorial says it is known to seize and i guess it did. i ended up giving up because i was gonna strip the **** out of it if i kept going.
does anyone have any suggestions as how to get that screw out without destoying it since i still need it afterwards?
thanks,
ryan
Old Aug 31, 2002 | 03:57 AM
Felix Wankel's Avatar
Super Newbie
I had to cut a slot in it and use a flathead nut driver bit in a ratchet to get it out.
Old Aug 31, 2002 | 02:47 PM
Liquid Anarchy's Avatar
We come with the Hardcore
I just cut the end-peice off with a dremel. I tried the above-mentioned method, and stripped it again.
What harm could a spinning metal sleeve do?
demetlaw
Oct 2, 2015 06:22 PM
musker
Oct 1, 2015 05:58 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
