should i get a new hood?
Old Aug 30, 2002 | 10:18 PM
fdslave_g's Avatar
A capital FD barbie
I'm driving FD3S with light mods. (Blitz muffler, ARC intercoller, supersound blow off, Knight sport ECU, etc.) I used to have TD-07, but now as it has been broken I'm using original twin turbo.
The problem is the car is overheated everytime i go beyond 220 KM/hr. (132 Mile per hr. may be I'm not sure abt mile). Some of my friends told me that a good hood could help, so any suggestion for new hood?
Old Aug 30, 2002 | 11:17 PM
jspecracer7's Avatar
1JZ powered
With the stock twins, you'll tend to overheat more vs. single turbo. What type of radiator do you have? An aftermarket hood does help, but helps more at a stand still vs. moving. I have both, an aftermarket hood and an aftermarket radiator. What type of Engine Management are you using again?
Old Aug 30, 2002 | 11:19 PM
user 84205's Avatar
220km WOW thats weird.
In my opinion it has NOTHING to do with a hood.
Maybe ECU, Radiator?
Nice looking car though...
Jason
www.jt-imports.com
Old Aug 31, 2002 | 12:55 AM
MazdaMike's Avatar
i dont now i got stock everything exept intake and downpipe i was doing 135 easy, no over heat. i got no vents or anything like that other than the stock equiped
Old Aug 31, 2002 | 08:53 AM
fdslave_g's Avatar
A capital FD barbie
I'm using standard radiator. What kind of radiator should I use then. For ECU what's the problem with it?
(most part of the car are standard, except those I already mention)
If I change those downpipe and intake stuffs would it be better??
Gosh! help! HELP!
Ps. the engine room is very hot, but I thought it's common. ;( or is it just because Thailand is hot?? ;(
Old Aug 31, 2002 | 10:03 AM
Mahjik's Avatar
Mr. Links
If you still have a pre-cat, then the downpipe would be your best bet to start with. The pre-cat is basically a small nuclear reactor that generates heat in the engine bay.
Old Aug 31, 2002 | 11:14 AM
From: Minnesota, now in FL and I dont think I'm goin back
Yea, get a DP, and maybe a new radiator. I dont know how much an aftermarket hood would really cool your car down. It would work but, a new radiator would help more IMO.
Mike
Old Sep 2, 2002 | 11:09 PM
fdslave_g's Avatar
A capital FD barbie
hey! where are posts gone!
Old Sep 2, 2002 | 11:14 PM
fdslave_g's Avatar
A capital FD barbie
okay! let's do this again!
What good does these DP does...
And should I get rid of pre-cat, will it effect any bad to the car? and If it help reducing the heat is it helping much???
Sorry bout asking so much... well, I'm a new driver :P
Old Sep 2, 2002 | 11:18 PM
Mahjik's Avatar
Mr. Links
Looks like a server/forum crashed and the forum was restored from a backup.
Anyways, your car is overheating. Are you using the stock temp gauge or do you have an aftermarket one?
What kind of coolant mixture are you running (100% anti-freeze coolant? 50% coolant 50% water? Water wetter? Evans?).
The car shouldn't overheat just from some spirited driving. Have you had the cooling system pressure tested?
Old Sep 2, 2002 | 11:28 PM
fdslave_g's Avatar
A capital FD barbie
Is it true that single TD-07 will get heated harder than original turbo?
Well, still when I had my single turbo on the car was overheated too.
The gauage is the stock temp guage and it climbing up to H when I go over 220Km/hr. I have to dlow down to 180-190 to keep it down.
Old Sep 2, 2002 | 11:33 PM
Mahjik's Avatar
Mr. Links
Single turbos usually generate less heat than twin turbos.
Sounds like your cooling system has a problem. When was the last time you had the cooling system flushed or pressure tested?
Even with stock equipment, you should see the stock temp gauge rising above the mid-point at 130mph (about 220 km/hr).
Old Sep 3, 2002 | 12:00 AM
Quivver's Avatar
Did you say your using the stock ECU with the mods you have even when you had the single turbo?
Old Sep 3, 2002 | 12:06 AM
fdslave_g's Avatar
A capital FD barbie
I'm using Knight sport ECU.
And I havn't got any check on the cooling system flushed and pressure tested. I thought the machanic would do that, now I guess he didn't.
I'll go run that check
Old Sep 3, 2002 | 12:14 AM
Quivver's Avatar
hey fdslave_g, is that you on the website you have linked to your posts, if so I find it really cool that your a girl driving a FD, never see that here in the US, or at least not around FL. Sorry to be off topic just thought I would let you know that I admire that
Old Sep 3, 2002 | 12:27 AM
fdslave_g's Avatar
A capital FD barbie
Yea that's me. surpise ha? I'm the only one around here as well.
But the shame is that I'm not quite good fixing the car myself, so I'm here to improve myself.
Thank you anyway
Old Sep 3, 2002 | 12:41 AM
RedX7's Avatar
I swear my car hates me!
I'd have to agree with everyone about flushing the coolant, and possibly getting a new radiator, and a downpipe. Good luck.
ls1swap
Jun 3, 2024 03:25 PM
