I tried searching already
Old Aug 30, 2002 | 03:16 PM
jeff_oner's Avatar
and got this error a bunch { Warning: Unknown modifier 'a' in /var/www/html/rx7club/forum/admin/functions.php on line 266 }
I don't really care about the error, but what I was wondering was, about the timing and octane.
I want to play with the timing but I have heard that you need to run a higher octane to avoid the pings.
any truth to this, also I have heard that 20* advance is the optimal setting.
I just don't want to do something then be like, "wow my car is fast" then PoP.
that would suck so I want to do it right.
Old Aug 30, 2002 | 03:40 PM
NixxoN's Avatar
Go into the forums section before you click on the search button, for some reason from the main page you cannot access some stuffs.
"I pitty da foo' who can't use da forum!" - Mr. T
Old Aug 30, 2002 | 03:45 PM
jeff_oner's Avatar
I tried from the forums section, and in the 2nd gen section and from the lounge, it still gave me the same error.
Old Aug 30, 2002 | 05:20 PM
DaleClark's Avatar
RX-7 Bad Ass
To answer the question, yes, you need to run higher octane as a preventative measure when playing with the timing. But, it's REALLY hard to gain much with timing - it's really something that has to be done on a dyno. Just turning the crank angle sensor can give you a small amount, but not enough to worry about.
The 20 deg. advance thing is for people with aftermarket fuel injection systems and doesn't apply to stock EFI systems.
I'd save up and get a Super-AFC if you want something that you can do some tuning with - much better results than messing with the crank angle sensor.
Dale
Old Aug 30, 2002 | 05:40 PM
BlackFC's Avatar
Acctually timing can mak ea HUGE differance in power. The feeling of 17deg advance and 22deg advance in my Talon was ungodly. Throw in some race gas pump it to 29psi and hit up 27deg of advance, a good 50 - 75whp gain from pump gas settings. Obviously your gains will be proportional, so an NA RX7 won't get that much extra power, but timing control is a VERY important part of the equation.
Daniel
Old Aug 30, 2002 | 07:12 PM
deadRX7Conv's Avatar
Opinions are like........
I run my 'vert advanced. I haven't had any pinging/detonation problems with 89 octane and about 15 degrees advanced. It made a helluva power difference in my heavy vert plus my spark plugs stay cleaner, car starts instantly, and runs great(so far). I've notice that I don't shift as often as before because the car pulls better.
Also, my cooling system is in tiptop shape. I can sit in blistering heat/traffic without the gauge ever going over half. If you have ANY cooling issues, do NOT advance the timing. It is important that the additional heat that the engine creates has somewhere to go. The minor intake air temp drop caused by the throttle body mod is also recommended.
Advancing timing is risky with low octane fuel, is risky with tired motors, is risky with marginal cooling systems, and is really risky if you don't have $1800 for a rebuild in case you break something.
Old Aug 31, 2002 | 03:25 AM
jeff_oner's Avatar
^bump^
Old Aug 31, 2002 | 10:45 AM
Rotorific's Avatar
I dont know a damn thing
black fc a talon is so different...in an rx7 you only need to run 89 with your timing advanced you may need to run 93 or 91 when you take out the cas and turn it then put it back in thus giving you more timing...
Einheri
Oct 7, 2015 12:23 PM
FC3S Timmy
Oct 2, 2015 08:08 AM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
Postman09
Sep 29, 2015 11:23 AM
Jingkun
Sep 28, 2015 01:53 PM
