what causes "hard" starts in a T2?
Old Aug 30, 2002 | 01:11 PM
jetfire76's Avatar
Gas Guzzlin' Tire Junkie
quick question...is there anything i can do to prevent my FC from having a "hard" start or not starting at all? i know it sounds stupid. why does it seem like the car is hard to start when too warm?
i wanted to search but didnt know the proper terms to search for.
thanks!
Old Aug 30, 2002 | 01:14 PM
Turbonut's Avatar
Flooding...Leaking injectors.
Normal problem when injectors leak fuel when hot. Plenty of threads.
Old Aug 30, 2002 | 01:16 PM
zyounker's Avatar
root
it probably also has to do with compression. usually high mile engines see this..
Compression is low and the injectors are not very good.. it causes the car to flood really easy.
-Zach
Old Aug 30, 2002 | 01:25 PM
jetfire76's Avatar
i have an anti-flood module installed.
thanks for the info.
Old Aug 30, 2002 | 01:46 PM
Aaron Cake's Avatar
Engine, Not Motor
If this "anti-flood" module is the one Mazdatrix sells, remove it immediately. It can cause fuel starvation..lean=dead engine.
Anti-flood modules will do nothing if your injectors are leakig or you have low compression. Injector cleaning is pretty cheap, so getting it done is good practice.
Old Aug 30, 2002 | 02:20 PM
jetfire76's Avatar
this is the anti-flood module i have.
http://www.our.net.au/~pnt/afm/rx7_RX7.html
Old Aug 30, 2002 | 02:31 PM
Aaron Cake's Avatar
Engine, Not Motor
Looks like it cuts the fuel pump on starting. It's a bandaide solution, not a fix to the actual problem with is more than likely leaking injectors.
Old Aug 30, 2002 | 02:46 PM
jetfire76's Avatar
thanks. i'll check it out.
i was planning on replacing the injectors anyway. even though my car is still stock would it hurt for me to get slightly bigger secondary injectors(720cc?) in preparation for the mods i plan on doing that will require more fuel?
Old Aug 30, 2002 | 04:04 PM
HAILERS's Avatar
HAILERS
A fellow named AKAGEALS fixed his broken bac, and one of the side effects was he has no problems starting anymore. I believe the bac is wide open when starting the car, then after the car is idling, goes into the feedback mode. See the 89manual if you think that is wrong.
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
