Gas grade?
Old Aug 30, 2002 | 01:04 PM
Furious D's Avatar
Gas grade?
What grade gas do you guys use? Also mention which Rex you have?
Old Aug 30, 2002 | 01:16 PM
jsotelo's Avatar
I have run from California 91..our high octane.. down to 87 and I really don't notice any difference with my 1987 base.
Old Aug 30, 2002 | 02:07 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
For NA's in stock form at least
Factory recommendation is for regular unleaded. However, running a tank full of Premium once in awhile would be good as the extra detergents will give your injectors a bit of cleaning.
Old Aug 30, 2002 | 02:08 PM
Ardent_Psyclone's Avatar
Buckler of Swashes
87, my car seems to run much better on the lower octane gas. N/A.
Old Aug 30, 2002 | 09:30 PM
Icemark's Avatar
Basicly stock NA cars have been dyno tested many time with all the verios grades and in most cases there is more HP in using octanes of 89 or 87.
Modified cars or T2 models with the knock sensor however show increased HP using octane 91 or better (if available in your area).
Old Aug 30, 2002 | 10:02 PM
Tec's Avatar
Tec
87 turbo II
100 octain avation fuel $1.85 gal
going to try C16 next tank! 114 octain leaded 7.08 gal
Old Aug 31, 2002 | 05:16 AM
Check the owners manual, it will tell you what grade to use, for turbo II ur supposed to use 91 octane for n/a's regular 87 octane should be fine.
Old Aug 31, 2002 | 10:36 AM
Rotorific's Avatar
I dont know a damn thing
Rx7s are supposed to run the lowest octane they can so 87 is what you are supposed to run Ive been messing with my timing so i am running 89 but thats only for timing reasons
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
musker
Oct 1, 2015 05:58 PM
rattlehead
Sep 25, 2015 10:55 PM
Devon Murray
Sep 25, 2015 09:41 AM
