Cooling the horses
Old Aug 29, 2002 | 09:40 PM
Marcel Burkett's Avatar
Question Cooling the horses
I decided to mount my large NPR in front (in the nose) of the car so I can go back to a stock mount upgraded radiator , question is after reading about the various ones you guys use I am still unsure about which to get , which would be able to effectively cool say ....... 500rwhp worth of heat ? , remember its a street car , 1/2 BP , T66@18-25 psi , H2O inj. etc , etc , thanks again guys.
Old Sep 3, 2002 | 01:54 AM
bcty's Avatar
Boost This!
i would say try evans for sure.. see how that does to your temps
Old Sep 3, 2002 | 04:31 AM
AJC13B's Avatar
10.32 @ 133
I have the factory radiator, clutch fan and shroud and have never had any overheating problems
Old Sep 3, 2002 | 11:09 AM
With which one of the after market ones ? . , I like the KOYO because of the size but I am a bit concerned about cooling air flow.
Old Sep 7, 2002 | 11:04 PM
Can some one please answer ? ..... ,Koyo or Fluidyne?.
Old Sep 8, 2002 | 12:56 AM
Ryde _Or_Die's Avatar
Not sure on an FD but on my FC the fluidyne helped out alot. Very high quality piece. I would expect the same from the FD one.
Old Sep 9, 2002 | 06:05 PM
Thats what I have been reading but , not wanting to be an *** , but I would really like an answer from someone with a high horse power car , I expect to be making a bit of power when I am done and would like to buy the right radiator and not have any problems . Any one with a high HP car using either of these radiators ?.
Old Sep 9, 2002 | 10:30 PM
gsxr's Avatar
fluidyne looks like it is built the best but use a high cfm electric fan
Old Sep 9, 2002 | 11:50 PM
Tom93R1's Avatar
gross polluter
Have you ever seen tha Koyo? If that thing isn't overbuilt I don't know what is!!! I admit I have never seen a Fluidyne in person but I couldn't imagine anything being built better than my Koyo.
Old Sep 10, 2002 | 07:20 AM
I intend to use the stock fans which I have wired to be turned on simultaneously by the E6K when it sees 190deg. .
Old Sep 14, 2002 | 04:08 PM
Ok FINE !!!! , since nobody wants to answer me I will go with the FLUIDYNE , since I haven't read one complaint about that one , I don't think the extra half inch more on the KOYO would be worth the risk ......... later.
ls1swap
Jun 3, 2024 03:25 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
carid
Vendor Classifieds
Sep 10, 2015 09:24 AM
