Gasmilage without TPS
Old Aug 29, 2002 | 01:52 PM
Iscar's Avatar
I don't post much here, but I have a question for you guys--already did the search.
I have an s4 TII.
How bad will my gas milage be if I disconnect my TPS?
Old Aug 29, 2002 | 02:17 PM
KNONFS's Avatar
B O R I C U A
I don't think you will be able to run the car at all.
Old Aug 29, 2002 | 02:19 PM
SonicRaT's Avatar
Super Raterhater
Yes, you can run without the TPS (Just ask Kevin Landers (hypntyz7)) However, some car's hate the idea of it and run like ****, others run just fine without it. Best bet is to leave it on, no real advantage to taking it off.
Old Aug 29, 2002 | 02:21 PM
Aaron Cake's Avatar
Engine, Not Motor
The car won't rev past 2500 once it's warmed up. You NEED the TPS to operate the car. It is an essential part of the EFI system.
Old Aug 29, 2002 | 02:25 PM
Iscar's Avatar
Just to clarify, this would only be temporary. My current TPS is bad; and I am ordering a new one. Before the new TPS gets here, I will try to run without one.
Old Aug 29, 2002 | 02:26 PM
SonicRaT's Avatar
Super Raterhater
Aaron: Landers did it without a problem, I drove around my 87 without one, had no issues revving...
Iscar's Avatar
So the ECU needs to see a resitence between 1k and 4-6k ohms in order for it to operate correctly?
Old Aug 29, 2002 | 02:27 PM
SonicRaT's Avatar
Super Raterhater
Check out the FSM for the resistance specs, should be ~1K at closed, and no more than 6 at WOT.
Old Aug 29, 2002 | 02:32 PM
Iscar's Avatar
With the TPS disconnected the ECU will see infinate resistance. FSM says no more than 6.
What will the ECU do if it saw an resitance more than 6?
Old Aug 29, 2002 | 02:34 PM
SonicRaT's Avatar
Super Raterhater
Causes hesitations/bucking/etc symptoms if it's more than 6.5K or 7K (can't remember which?) And if the ECU see's the TPS is malfunctioning (infinite) It'll give it a fixed adjustment of 20% open.
Old Aug 29, 2002 | 02:38 PM
Iscar's Avatar
Ah ha! The exact problem I am trying to solve by replacing the tps. (bucking)
Sorry to ask; but is that 20% throttle opening?
SonicRaT's Avatar
Super Raterhater
Yes, it is.
Old Aug 29, 2002 | 02:45 PM
Aaron Cake's Avatar
Engine, Not Motor
I have no idea who Landers is, but whenever I have forgotten to plug a TPS back in (yes, I do that on a regular basis after adjusting them) the car runs like absolute crap, sputtering and backfiring above 2500 when warm...Runs alright cold though...Maybe Canadian cars are different? Doubt it though.
Old Aug 29, 2002 | 02:46 PM
Iscar's Avatar
Thanks for the info.
Old Aug 29, 2002 | 02:50 PM
Iscar's Avatar
As long as the TPS gives me the fixed adjustment, I should be okay. It seems that some cars are different.
Arron Cake: The car that ran like crap, was it a TII?
Old Aug 29, 2002 | 02:51 PM
SonicRaT's Avatar
Super Raterhater
Aaron: Landers is hypntyz7, the Rotary Ressurection guy. It depends on the car, some it runs ok, some it doesn't.
Old Aug 29, 2002 | 02:54 PM
Aaron Cake's Avatar
Engine, Not Motor
The cars that ran like crap were all '86-'88s, mostly NA. I don't work much on the '89+ cars, so I have not really forgot to plug the TPS back in on one...Probably does depend on the rest of the car though...If the EFI system is in perfect shape, removing the TPS will cause major issues. If there are problems (ie. vacuum leaks, dripping injectors) then the effects might not be noticable.
Old Aug 29, 2002 | 02:59 PM
Iscar's Avatar
Guess I won't know until I try. Thanks again for the comments
Old Aug 29, 2002 | 03:11 PM
rxguru's Avatar
completely wankelfied
Try to back it all the way out, I tricked one of mine that way. I wouldn't run it that way for a long time though I guess the other option is to take it off but leave it plugged in so it registers WOT all the time. I know it sucks new ones are like 170 bucks from Mazda and be careful if you buy a used one I went through four used ones before I got a good one.
Old Aug 29, 2002 | 03:13 PM
Aaron Cake's Avatar
Engine, Not Motor
Geeze, I can get good ones all day from the wreckers...Remind me next time I go to get them all...I'll put on eBay and make a fortune.
Old Aug 29, 2002 | 03:15 PM
I run my car without a TPS. Its getting fixed! It doesn't run the best with out it heh but mine idles and runs fine!
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
