Sponsored by: CARiD
What are the adjustments for HKS SS BOV??
Old Aug 28, 2002 | 11:42 PM
BATMAN's Avatar
There seem to be different sound levels that u can do.
What are the pros and cons?
Old Aug 29, 2002 | 03:22 AM
DeNguyen's Avatar
Theres a sound adjustment?
i thought it only adjusted spring stiffness?
Old Aug 29, 2002 | 08:34 AM
BATMAN's Avatar
nope, it's the blow off valve
Old Aug 29, 2002 | 02:03 PM
j9fd3s's Avatar
Community Builder
Pros: The louder the BOV, the more teenyboppers you will attract at high school parking lots
Cons: You may also attract the child safety committee
mike
Old Aug 29, 2002 | 02:12 PM
vudoodoodoo's Avatar
I know of the nut and bolt out on the back that's used for adjusting the spring tension or whatever. Tighter - holds more boost, loose - blows off at lower boost.
Mine isn't that loud either. I think it's adjusted too tight. My friend has the same one on his Supra and it's LOUD.
Old Aug 29, 2002 | 05:49 PM
BATMAN's Avatar
what's with the mode that flutters?
Old Aug 29, 2002 | 06:39 PM
peejay's Avatar
Old [Sch|F]ool
wouldn't that be "too tight"?
Old Aug 29, 2002 | 07:01 PM
Doesn't it "flutter" when you have compressor surge? Isn't that a bad thing?
Old Aug 30, 2002 | 05:26 PM
peejay's Avatar
Old [Sch|F]ool
but it sounds cool man! screw turbo life!
- PJ (why bother having a BOV at all...)
Old Aug 30, 2002 | 06:18 PM
Damnfuct's Avatar
Give this guy a medal!
i think when it's hard, the pressure wave heading back to the turbo has to be stronger to push it open, hence the BOV opening less.. less open = more hiss!
Old Aug 31, 2002 | 11:01 AM
Andrew Harper's Avatar
What's the best setting for the Spring Adjustment (default seems about midway).
My unit came with only Jap instructions and I don't want to cause any damage to the turbos!
Old Aug 31, 2002 | 01:21 PM
BATMAN's Avatar
my buddy adjusted it so that it makes no noise.
so he must be doing damage...
