Need advice with this setup
Old Aug 28, 2002 | 08:11 PM
agent712's Avatar
I'm kind of curious as to what kind of power this setup I'm building will produce.... I'm going to build a custom intake w/ 2.5" free flowing pipes and build a box around it with a duct for fresh air from the front bumper. The car already has a 3" downpipe. Plan to add the catless midpipe and a good cat back exhaust (probably Racing Beat). What kind of power will this setup make? What will I need to do computer wise? Would the Apexi A/F controller be adequate? If not, direct me to a good cost effective ecu upgrade.
Thanks for the help
Chuck
Old Aug 28, 2002 | 10:54 PM
agent712's Avatar
ttt
Old Aug 28, 2002 | 11:31 PM
P'cola FD's Avatar
Hamado things my way!
A used Pettit, M2, G-force, etc. computer can run from 300-500 dollars. You can use an AFC but it will not be as good, and you must run stock boost and no more. That setup with a good engine could make from 265-280hp I would think.
Old Aug 29, 2002 | 02:03 AM
duboisr's Avatar
Garfinkle has a PMS for sale , call him in Murfreesboro, Tn
Old Aug 29, 2002 | 05:07 PM
agent712's Avatar
I'm curious as to what the reason is behind the afc not being as good as a reprogramed ecu?
Thanks
Chuck
Old Aug 29, 2002 | 07:02 PM
Kahren's Avatar
i am not a girl
repgrammed ecu alters the timgin as well, nto sure what else. with full exhasut i woudl get an intercooler as i am sure u will want to run past the 10 psi and the stock intercooler is not efficient at those levels. with that and the proper fuel u will be good for over 300 whp.
Old Sep 1, 2002 | 08:56 AM
agent712's Avatar
What if I got an A/F controller and timing controller? Would you consider that adequate enough to do the job? The only problem I can see is the resolution on those devices being a little slow.... but they're not that bad either.
Thanks
Chuck
Shainiac
Jul 17, 2019 02:20 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
Bauer778
Nov 4, 2015 04:42 PM
risingsunroof82
Sep 7, 2015 01:11 PM
