temp guage at 1/2?
Old Aug 28, 2002 | 06:29 PM
temp guage at 1/2?
lately my car's temp gauge has been at 1/2 or slightly above once warmed up. It used to run at about 1/3, and my rx7 with bad coolant seals runs at 1/3.
Is this something to worry about? is there any quick/cheap fix? thanks
Old Aug 28, 2002 | 07:44 PM
cool3865's Avatar
depends on what kinda 2nd Gen you have ma car runs 1/2 way up and thats its normal and some run at 1/3, you shouldnt have to worry to much about it untill you notice it starts climbing
Old Aug 28, 2002 | 09:20 PM
Ryde _Or_Die's Avatar
Try searching for "overheating" or the such and you should get shitloads of info. Easy/quick?
Thermostat, radiator cap, coolant flush
Expensive/time consuming?
radiator,fan clutch, waterpump(not very hard or expensive if you know what your doing), water seals
Old Aug 29, 2002 | 01:14 AM
The Ace's Avatar
Greek Power
eerrrmmmmm, TIIs always run at 1/2. N/As run at 1/3. So, if your's is an N/A, then it is slightly overheating, but if it stays there, then you just need to clean everything up (no real problem, just flush, clean rad, changes gaskets, you're done )
Old Aug 29, 2002 | 02:20 AM
DCmina's Avatar
I think S5 n/a run at 1/2. Mine does.
The S4s n/a I've seen run at about 1/4.
Old Aug 29, 2002 | 02:41 AM
KenshinFC's Avatar
My S4 TII runs at 1/4. Should I worry about that? Being too low? Dunno...
Old Aug 29, 2002 | 07:35 AM
Mine too, and thats the highest it ever gets. Most of the time its lower than that.
Old Aug 29, 2002 | 07:42 AM
hybridracer's Avatar
I Post In The Nude
Might I also suggest a new temperature gauge, just for a little, you know, accuracy
Old Aug 29, 2002 | 09:56 AM
SoloIIdrift's Avatar
stock gauges = teh worthless
by the time the gauge moves it's too late. Get an aftermarket temp gauge such as VDO and tap the sender on the water pump.
Old Aug 29, 2002 | 01:22 PM
Ni5mo180SX's Avatar
White Comet
S4's are supposed to run 1/4 of the way up.
Old Aug 29, 2002 | 02:36 PM
Aaron Cake's Avatar
Engine, Not Motor
Actually, the stock S4 guages aren't bad at all. They're pretty accurate, although a little slow. The S5 ones are worthless, however.
Does it run hot in traffic, or on the highway? Both?
Old Aug 29, 2002 | 03:53 PM
Wankel7's Avatar
Haven't we ALL heard this
Just get an aftermarket. That is the only way to go.
James
Old Aug 29, 2002 | 06:03 PM
TurboSmoke's Avatar
Getting Boosted
what year of car do you have?? na or TII??
Old Aug 29, 2002 | 06:20 PM
it's an 87' N/A. seems to be at 1/2 in city and highway., but today on the way to school It was at about 1/4! it was only like 60 degrees, and raining. on the way back, back to 1/2 though.
I don't want to get a temp gauge now because I'm selling when I rebuild my other 87'. I'll get new temp. gauge for that.
Old Aug 29, 2002 | 08:11 PM
Jodoolin's Avatar
Minor point on gauge temp change. Recently flushed cooling system. Went to the trouble of dropping the bottom shield. Noticed a ton of leaves & debris between the oil cooler and radiator. Removed (very gently? with flat wooden paint stick and then blew out oil cooler from the front and between cooler and radiator (again gently) with compressed air. Car had 111,000 original but unsure care of original owner. Anyway, gauge on '90 NA went from 1/2 to about 1/8 inch lower. Tend to think it was removing debris rather than the flushing.
Old Aug 29, 2002 | 09:30 PM
Funklord's Avatar
i have an s4 t2. my car runs between 180 and 190 degrees. its 1/5 to 1/4 on the stock gauge.
Old Aug 29, 2002 | 10:47 PM
Digi7ech's Avatar
I break Diff mounts
Why not get a guage? It's not like you can't take it out of the car when you sell it.
My car was running at about half to 3/4 on the stock guage. I got an autometer guage and found I was running at about 210-250+.
My car would run at 210 in the city and over 250 on the highway when I was over 80MPH.
I put a new thermostat in and flushed the Rad and put some water wetter in. Now I my running temps are 1/4 up the stock guage and are 190-city and 208ish max on the highway .
I would check the Thermostat.It's very cheap and easy to replace.
Old Sep 18, 2002 | 02:48 PM
rx7sam's Avatar
My 91 S5 is @ 1/2 too, it sucks to see there. And my cousin's 89 GTU stays at 1/4. Whats the deal again? I've had my car a year and 3 months. Havent changed the anything except the trans. fluid and oil changes. Mariah Motorsports is doing the Major Tune-Up which is gonna cost me $477.52.
Old Sep 18, 2002 | 03:34 PM
Aaron Cake's Avatar
Engine, Not Motor
The S5 is SUPPOSED to be at 1/2. Any low is NOT proper operating temperature and will cause reduced fuel mileage, reduced performance, and fouled plugs + cats.
musker
Oct 1, 2015 05:58 PM
