do you think my rims are bent a little??
Old Aug 26, 2002 | 10:15 PM
93redFD's Avatar
I wrecked my fd saturday and I ran over a median that was about 8-9 inchs tall with stock size tires and rim, do you guys think they are bent??? if they are bent im getn some nice after market wheels with that nice check they give me.. I dont want to make any big plans and find out there not bent at all..
Old Aug 26, 2002 | 10:40 PM
maxcooper's Avatar
WWFSMD
I think it is highly likely that you bent some rims. Put them on a machine and check the runout if it isn't obvious.
-Max
Old Aug 27, 2002 | 09:41 PM
93redFD's Avatar
Old Aug 28, 2002 | 02:35 AM
Juan's Avatar
Im a tall midget.
You can try taking them to a tire shop and mount the wheels on the machine that balances tires. Im guessing that this will work. By looking at the way the wheel spinds you can tell it its bent.
Old Aug 28, 2002 | 02:36 AM
1FooknTiteFD's Avatar
Ghost Ride the Whip
one way you can tell if your wheels are bent is if you have severe vibration (from the steering wheel to the entire car). If you're wheels are bent then on the freeway, you will definitely feel your car vibrating after 80+mph
Old Aug 28, 2002 | 11:21 AM
neuroticinsomniac's Avatar
Reborn Rotorhead
how fast were you going? you probably have more damage than just bent rims if you hopped a big median. i would take it to a shop that also does alignment.
Old Aug 28, 2002 | 05:12 PM
93redFD's Avatar
Old Aug 28, 2002 | 05:15 PM
93redFD's Avatar
well I cant drive the car right becuase one wheel is totaly fucked.. I got knock out a few sec but , running over the median woke me up a lil. 15-20 mph i would say
Old Aug 29, 2002 | 04:00 AM
duboisr's Avatar
you can check them your self at home. jack up the wheel in question and turn it with a dial indicator touching it , check rro and lro , radial run out ,lateral run out ,
Old Aug 29, 2002 | 11:16 PM
1stgenplayinrough's Avatar
Old Sep 3, 2002 | 03:50 PM
Aristotle's Avatar
How did you run over the median? Was it your fault?
Old Sep 3, 2002 | 08:14 PM
Jerk_Racer's Avatar
A little this and a little this as well maybe ?
Coochas
44
Nov 5, 2019 11:08 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
