Megasquirt best write up for MS2 going cop
Old 09-08-15, 09:04 PM
gfd263's Avatar
GA best write up for MS2 going cop
Looking to mod my MS2 v3 to run cop or LS1 coils in RX8 mode. Car is a 1st gen 12a turbo. There are several write ups, but none completely answer my questions.
The DIY Autotune write up mentions RX8 mode, but does not tell where you get Spark D output.
Aaron Cake write up uses FC ignition
The write at http://www.msextra.com/doc/pdf/MS2V30_Hardware-3.4.pdf has 2 step by step mods which cover outputs for Sparks A, B, C, and D and some tuner studio settings. It does not mention the second input for trailing timing. It does mention a second input for cam signal for use in a piston engine. Does Rotary mode use that?
Can somebody give me just a little direction here?
You guys have been great in the past and it has been very appreciated. This car has come a long way and did it's first 2 autocrosses this year. Hoping to really be ready come next spring.
Danny
1979 RX7 12ATurbo SOLO2 DM and GRM2016 entry
Old 08-28-16, 08:58 PM
wankelbug's Avatar
I know this is an old thread. I did this mod and it works well. You need to build the led circuit in the proto area. Triger from js11 iirc and add the pull up resistor. Run your wire to an open pin on the db37.
gfd263
Megasquirt Forum
04-21-18 05:51 PM
gfd263
Megasquirt Forum
03-09-14 11:19 AM
Jobro
Megasquirt Forum
51
05-30-12 08:31 PM
Rub20B
Megasquirt Forum
32
12-20-10 05:40 AM
Jakekitz
Megasquirt Forum
01-18-08 03:41 PM
Quick Reply: Megasquirt best write up for MS2 going cop
