Thermostat question....
Old Aug 25, 2002 | 08:28 PM
Agent_D's Avatar
rawr
well since i been running without one and im gonna buy an OEM i was wondering if this would be ok to use for about a week
its a stant Superstat, its not specifically for the RX-7, its a 160º but it is the same size as the 180º version they had for it, 54mm, will this work ok for about a week or so??
Old Aug 25, 2002 | 09:04 PM
Agent_D's Avatar
rawr
well, i just started it and let it idle for about 10-20 mins, never even got to 1/4 on the guage, now to go drive it and see how it turns out.
i also found my idle problem that i thought was a result of my TB port job, i left a vac hose off lolol
Old Aug 26, 2002 | 12:03 AM
Silkworm's Avatar
Has been.. hangin' around
Should be OK, IMHO. I've never really bought into the OEM being so much better than aftermarket gig.
PaulC
Old Aug 26, 2002 | 12:37 AM
Agent_D's Avatar
rawr
hehe, yea me too, i only buy into certain OEM things that are proven better
drove it around some more, seems to be great, stays right below 1/4 guage, ill find out how it work tomorrow, it wsa only like 50 degrees tonight, so ill test it out int he heat of the day, and redline it a couple times and see what hpapens
Old Aug 26, 2002 | 10:22 PM
Rotorific's Avatar
I dont know a damn thing
The lower the better that just means that it opens at 160 instead of 180 it is seen as a mod to use those
Old Aug 26, 2002 | 10:43 PM
mazdaspeed7's Avatar
mad scientist
Trivia question of the day: Do you know why? I do, and I know Agent D does, because I explained it to him.
Old Aug 26, 2002 | 11:12 PM
Evil Aviator's Avatar
Rotorhead
Oh yes, I would love to hear this explanation, too.
BTW, the OEM thermostat IS better than most of the aftermarket thermostats. The main problem with the aftermarket thermostats is that they seem to fail after a few months, causing violent pulsating in the upper heater hose. I have seen some which were only single stage, and others without jiggle pins. I suppose that there may be some good aftermarket thermostats out there, but I have yet to see them, and I don't think it's worth saving $10 on the thermostat to risk frying your $2,000+ engine.
Old Aug 27, 2002 | 01:30 AM
Agent_D's Avatar
rawr
well drove it around today in 95 degree weather, stop and go traffic driving for about an hour, never got to 1/4 on the guage, but stayed just below it
Old Aug 27, 2002 | 03:17 PM
RETed's Avatar
The other reason for NOT using the aftermarket thermostats is the fact the OEM Mazda ones open a whole lot faster.&nbsp The rotary engine heats up very quickly.&nbsp The aftermarket 160degree one might start to open faster, but the stock 190degree OEM Mazda one will beat to full open most of the time.
-Ted
MidnightOwl
Sep 25, 2015 10:24 PM
erevos
Sep 15, 2015 09:19 AM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
