Pop off valve
Old Aug 25, 2002 | 02:11 PM
Pumped's Avatar
Pop off valve
anyone using this?
and where to buy it?
thanks
Old Aug 25, 2002 | 02:15 PM
BrianK's Avatar
not using it but, you can buy them here:
http://www.rx7.com/cgi-local/3catalog.cgi?cat=9&part=4
(among other places)
Old Aug 25, 2002 | 02:19 PM
ErnieT's Avatar
Living life 9 seconds at a time
Its a good way to overspin your turbo. Not a wise choice. And if your tuned right you'll never need one.
Old Aug 25, 2002 | 04:37 PM
ROTARYFDTT's Avatar
Ding King
They are not a good idea as ErnieT stated. If you are worried about boost creap and if a POV will prevent it. Check this thread out, pressurized found a badass way to prevent it, I am gonna try what he did when I get a MP.
anyway, hope this helps.
https://www.rx7club.com/forum/showth...threadid=49681
here is a link to RX7.com and their info. on it.
Old Aug 25, 2002 | 05:42 PM
Mr. Stock's Avatar
1993 RX7 R1
But it will prevent you from hitting high boost pressures and popping your motor if your waste gate fails.
I am think of getting one since I prefer to popping the pop off valve/turbo instead of popping my motor.
Old Aug 25, 2002 | 07:13 PM
Speedie7's Avatar
I agree 100% with Mr. Stock...if you have to pick between losing a motor and turbos, the choice is obvious. If the POV opens at a boost corresponding to a MAJOR failure of the wastegate, I think it's a great idea, but for no other reason than this. Boost creep issues need to be addressed in another way.
Old Aug 25, 2002 | 07:17 PM
ROTARYFDTT's Avatar
Ding King
yup speedie7 pretty much said what I was trying to get across......thats what I was trying to say by posting a link to that thread.
Old Aug 25, 2002 | 08:47 PM
GsrSol's Avatar
Z06 powered FD
If you have a boost controller set at say 12psi, and the pov set to open at around 14psi, how will that overspin your turbos?
That is what I thought the job of the pov was. To set it to open at higher then normal boost levels so it will bleed the excess incase the wastegate fails.
Old Aug 25, 2002 | 09:24 PM
ErnieT's Avatar
Because when it works, all it does is vent excess boost causing your turbo or turbos to keep spinning. I've discussed this with many tuners like Ray Lochead, Demetrios K, and Pepe Loco.....All say its a bad idea.
Old Aug 25, 2002 | 09:59 PM
GsrSol's Avatar
Z06 powered FD
What you're saying is that it vents all the time. That would overspin the turbos and be a boost leak, but if you never run 14psi it shouldn't be working, right?
So if you did hit 14psi it should open and vent excess boost preventing you from hitting 18psi and blowing the motor.
Old Aug 28, 2002 | 09:14 PM
Pumped's Avatar
well the reason i asked was after reading Gsrsol's post about popping his motor.
i have a profec b as well set 12 psi but i play with the settings time to time and thought the pop off would be beneficial incase of a over boost.
Old Aug 28, 2002 | 09:24 PM
Wargasm's Avatar
Weird Cat Man
I've got a POV on order.. I run 14 PSI, and I figure I'll set it for around 17-18 PSI so that it only comes into play in the event of wastegate failure.
ls1swap
Jun 3, 2024 03:25 PM
renjiv2
57
Jan 25, 2024 03:34 AM
Rotafuzz
Sep 30, 2015 09:55 AM
