Not a typical passenger window
Old Aug 23, 2002 | 06:16 PM
Question Not a typical passenger window
My passenger window will not go up or down by the passenger switch, however it does work with the driver side switch. Less voltage is being sent through the passenger side than the drivers. Any ideas how to fix this?
Old Aug 23, 2002 | 09:18 PM
Icemark's Avatar
Either the passengers window switch lock out is enabled
Or
You have a bad passenger's power window switch. If it is the switch, more than likely the 12V+ input is either disconnected or has bad internal contacts.
Old Aug 23, 2002 | 09:32 PM
fastrotaries's Avatar
W. TX chirpin Monkey
take them apart and clean them thouroughly. i scraped the contacts with an exacto knife.
Old Aug 23, 2002 | 11:19 PM
neither of those are the case, contacts are clean, and I wasn't thick headed enough to leave the window lock on, any other ideas?
Old Aug 23, 2002 | 11:41 PM
'Vert in Vegas's Avatar
OK, pull the door panel on the right side.
What is the voltage at the switch?
If you have a normal reading (12.6v) engage the switch while reading the voltage. What happens?
Old Aug 24, 2002 | 12:26 AM
sandmstreet3's Avatar
i have same problem
Old Aug 24, 2002 | 12:43 AM
Icemark's Avatar
I guess I am sorry I wasn't more clear, when suggesting that there was
Have you tested the 12V lead at the passengers switch and is there 12V+ resting on the lead???
and if so is there ground resting on the motor wires??? (there should be if the drivers switch still works the motor... but you still need to test).
If yes on both the above questions, then does the motor leads go hot when you activate the passengers switch either direction?
If yes, and the motor still doesn't move, then there is a bad contact in the switch.
If no, there is a bad switch (as described above when asking about 12V+) or you didn't do one of the above tests.
toplessFC3Sman
Mar 20, 2018 01:54 PM
