All of a sudden the passenger side window doesn't go up....
Old Aug 21, 2002 | 05:32 PM
EviLPeNeviL's Avatar
Can't live without boost.
It was just working fine in the morning and then at night the passenger side window won't close back up, it'll go down, but not back up.
What kind of problem is this and how do I go about fixing it?
Thanks for any advice.
Dan.
Old Aug 21, 2002 | 05:35 PM
darkside7's Avatar
have u ck the on/off switch?
Old Aug 21, 2002 | 06:08 PM
Yeah of course.
I toggled the on/off switch on the driver side a few times but the passenger side window just doesn't seem to want to go back up.
Old Aug 22, 2002 | 05:40 AM
Rated R1's Avatar
Oji San
Can you roll it up with the passenger door switch? If you have and it still does not roll up and you don't here the motor then the motor is probable shot. If you can roll it up with the passenger swith then the driver side switch is bad (common problem these days) and needs to be replaced.
Old Aug 22, 2002 | 11:09 AM
JUSTgotMINE's Avatar
ge new switches at mazdaformance...best price. I'm waiting for mine as we speak and will have my power window problems fixed this weekend!!!
Old Aug 22, 2002 | 12:04 PM
Street King's Avatar
*** Bless Texas!
OK OK OK all calm down. Iam going through this exact problem right now. Its the connector through the driver door going into the body of it. Some water might have gotten in the there. I have to pull mine off every now and then and clean the contacts because of oxidation. Just go and wiggle it a little and see if it will work.
Old Aug 25, 2002 | 10:49 AM
Die For MX's Avatar
i was buggin' out over this very subject like ten minutes ago. my passenger side window wasn't going up and i had no idea what to do. didn't even think of the on off toggle switch because i never use it. then i found this post, went out and toggled it on, thank God i don't need a new motor.
Old Aug 25, 2002 | 11:06 AM
R Xplicit's Avatar
OMG!! are you serious?
Old Aug 25, 2002 | 03:36 PM
ROTARYFDTT's Avatar
Ding King
yup same thing happened to me earlier in the summer. The connector street king is talking about was faucked in my car.
But I am wondering, is this a semi-common problem seeing the same thing happened to us right around the same time. But this is the first thread I have seen discussing the matter........interesting
sYnth.
Aug 19, 2015 06:27 PM
bURGRotary87
Aug 19, 2015 03:54 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
