how big can i go
Old Aug 17, 2002 | 10:11 PM
]unbreakable's Avatar
how big can i go
what is the max tire size on the gen 1 the tire size that will fit comfortable and no rub
Old Aug 17, 2002 | 10:17 PM
357's Avatar
357
Stratoflattener
I'll assume you're talking about the stock 13x5.5's on the S, GS, and GSL. I believe that I've heard the largest tire size that will fit comfortably is 205/60 R13. A great resource is www.1010tires.com. They have a tire sizing chart that tells you what tire/rim size combos will fit within the +-3% standard tolerance.
Old Aug 18, 2002 | 10:52 AM
jr69187's Avatar
i run 205/50 on the rear no problem and you can go wider with wider wheels 205 is the max.
jr
Old Aug 18, 2002 | 11:26 AM
MikeLMR's Avatar
'Last Minute' Rallying
205/50R13 is the STOCK size in the UK so they should fine on your 7
Old Aug 18, 2002 | 12:09 PM
Manntis's Avatar
add to cart
I'm running 205/50R16s with no problems.
Old Aug 18, 2002 | 04:57 PM
AJC13B's Avatar
10.32 @ 133
225/45/17
Old Aug 18, 2002 | 05:01 PM
Directfreak's Avatar
I am a Jeeper Now.
Originally posted by AJC13B
225/45/17
Steve, you rin that on all 4 corners? No Rubbing?
Old Aug 18, 2002 | 09:39 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Tub it and put what you want on it, plus kinda solves the storage bin rust problem LOL
cook11
V-8 Powered RX-7's
Oct 2, 2015 11:52 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
