Oil Pressure Light
Old Aug 16, 2002 | 10:50 PM
SiKoPaThX's Avatar
Porque tan serio?
Oil Pressure Light
Oil Pressure Light came on a few times tonight. Mostly above the 60 pounds range. My car has a small leak. IT's also about time to change the oil. Prognosis?
Old Aug 16, 2002 | 11:36 PM
SiKoPaThX's Avatar
Porque tan serio?
ummm, regaridng some other posts, this seems to be urgent....HELPPPP!!!
Old Aug 17, 2002 | 12:37 PM
Snook's Avatar
Tony Stewart Killer.
Check your oil level and if you are low add the same oil in there probably 20w50
If you are at the L on the oil stick you've lost a quart of oil
The oil leak could come from many places I found out.
the turbo return line, oil coolers, oil pan gasket or the filler stuff, or warped rotors and many more.
Fill it up with oil and drive it nice to a shop and have it checked out. Probably cam at pettit since you live down there
SnoOk
andyvideopro
Aug 20, 2015 10:55 AM
