turbo internals vs non-turbo
Old Aug 16, 2002 | 03:52 PM
jcmccool's Avatar
are there any internal differences between the turbo 13b and the non-turbo 13b other than the rotors?
what i need to know is can i rebuild a non-turbo motor, put in some turbo rotors, then bolt on an exhaust manifold and intake manifold for a turbo 13b and use a haltech e6k to control it all.
any help is appreciated
Old Aug 16, 2002 | 04:52 PM
Aaron Cake's Avatar
Engine, Not Motor
Considered searching?
Besides the ports and rotors, the internals are basically the same.
Old Aug 16, 2002 | 05:06 PM
Icemark's Avatar
On the turbo front housing (vs the NA):
Aux port was eliminated
and oil suction hole was added
in the intermediate housing:
Intake port and time is different.
air passage for the EGR was eliminated
Port air passage was added
water passage was added
oil level gauge pipe was shortend
oil filler pipe shape was changed.
rear housing:
aux port was eliminated
Front rotor/rear rotor housings:
water passage was added for turbo
Free flow port insert was used
port air passage opposite on turbo to the NA
Front cover:
oil return hole was added
on the rotors themselves:
Volumn of rotor recess enlarged
cromium plating applied to apex seal groove
side seals were impregnated with molybdenum disulfide
and flywheel was larger and heavier
Old Aug 16, 2002 | 07:14 PM
jcmccool's Avatar
wow, thats alot of stuff.
i guess it would be better to just sell the non-turbo motor and put that money toward a turbo motor.
thanks guys
Azevedo
26
Mar 1, 2019 09:19 PM
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
