Need help with 82 front susp rebuild
Old Aug 16, 2002 | 11:43 AM
my 82 front end drives me instead of me driving it. My alignment is fine but my steering wheel is very loose and puts my car all over the road. i still have factory wheels. could my problem be solved by replacing all of my front susp bushings and the bushings inside the steering 'box' so i call it? the 'box' is located under the brake booster with one nut to loosen. and if so, are the energy suspension bushings from victoria british any good? i would appreciate experienced advice on this one!
Old Aug 16, 2002 | 01:12 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
Go to the 1st gen section, you'll get more help there.
"Wandering" steering is a very common problem on 1st gens, and it can be tightened somewhat. There is a good webpage out tehre that explains it, unfortunately I don't have the link.
Th0m4s
Feb 26, 2019 02:04 AM
sYnth.
Aug 19, 2015 06:27 PM
