Apex power fc ques.....
Old Aug 16, 2002 | 12:07 AM
faisalk's Avatar
I want to buy the apex power fc for my FD. However my FD is a japanese edition 1995 right hand. Does this mean that I will have to purchase it from Japan or all the power fc's work irrespective of right hand/left hand or which edition. Also what modifications you can do with the power fc without gettin it tuned?
Old Aug 16, 2002 | 12:13 AM
the_glass_man's Avatar
Will u do me a kindness?
You should be fine. I believe that all PFC's are the same, with different revisions and such.
You may get more info from the PFC section.
Depending on what maps you get with you PFC, you should be good for all the boltons.
Or, it may just work with intake and catback.
Old Aug 16, 2002 | 12:17 AM
faisalk's Avatar
That means you have to tell them what modifications u have so that they send it pretuned for those modifications? isnt there a set standard like power fc comes factory tuned for cat back,intake,downpipe etc.? also can u play wid the numbers if u have a commander?
Old Aug 16, 2002 | 12:20 AM
You can mess with the numbers, but the PFC came with either a base map or base mod map.
The base mod one supporst more. Like DP, IC, etc..
Old Aug 16, 2002 | 04:22 AM
cash money's Avatar
Old School Member
dont japnese rx7's use the 16 bit pfc?
Old Aug 16, 2002 | 04:50 AM
spigot's Avatar
I'd check with the creators of the Datalogit, since they are probably the best equiped to answer the question outside of Apexi. http://www.fc-datalogit.co.nz/
Matt
Old Aug 16, 2002 | 04:54 AM
user 84205's Avatar
we use both....... 8 and 16bit... The 99 and up can use a 32bit...
Old Aug 16, 2002 | 12:49 PM
The PFC is 16 bit. Like a super nintendo
Old Aug 16, 2002 | 01:00 PM
TYSON's Avatar
WTF is wrong with it now?
What advantage does the 32 bit give? 250 RPM points vs 500 RPM points? Anything else
Old Aug 16, 2002 | 01:06 PM
Its like a playstation, makes for killer graphics. lol
Better resolution, more load points, etc..
To put it in perspective, the stock ecu on US FD's is 8 Bit, while the newer ones are 16 bit. Thats why they run a lil smoother from just a swap, or a swap to a PFC.
Haltechs are 16 Bit
PFC 16 Bit
Aem 16 Bit
Motec 32 Bit
Old Aug 16, 2002 | 03:44 PM
user 84205's Avatar
92-95......8-bit
96-99......16bit
99-current.....32bit
As for the PFC they did make an 8 bit computer. It just isnt heard of much since they only made it for 2 years and no one even used PFCs back then... Its around though..
Jason
www.jt-imports.com
Old Aug 16, 2002 | 04:03 PM
twinturborx7pete's Avatar
Juris Doctor
i'm still waiting on mine to show up..its on backorder.. putting the motor back together this weekend and plan on having it running, but no ECU! sucks...
Old Aug 16, 2002 | 06:01 PM
user 84205's Avatar
bummer...
I could have gotten you one...
There is no backorder here...
Jason
www.jt-imports.com
Old Aug 16, 2002 | 08:05 PM
jspecracer7's Avatar
1JZ powered
jspec and aspec pfc's are interchangeable.
rx7shirley
Sep 2, 2015 02:11 PM
