12a Dyno - some questions
Old Aug 15, 2002 | 08:22 PM
Dave-ROR's Avatar
First, a link to the dyno graph.
edit: will post the img asap.
What in your opinion would be causing the break up at high rpm?
The motor is a 81, 79 carb/intake manifold, base timing, header, exhaust with mazdacomp muffler, k&n, stock porting, etc.
Thanks for any info!
Old Aug 15, 2002 | 08:37 PM
Felix Wankel's Avatar
Super Newbie
I can't open the graph.
its a .wtdr
Old Aug 15, 2002 | 08:55 PM
mar3's Avatar
Administrator
When I did my dyno day, I adjusted fuel pressure with the Puro-crap in half pound increments. It liked 4 lbs., it did not like 4.5 lbs. It did the high RPM stuttering just like you said and we cut the run at 6800RPM. It was going to 7500 RPM before... The HP difference at peak was 113 rwhp for 4.0 lbs. and 96 rwhp at 4.5 lbs.!!
Old Aug 15, 2002 | 10:09 PM
Directfreak's Avatar
I am a Jeeper Now.
Now Mar3, you know that it it had been a Carter Fuel Pump, you would have made like the Magic 170hp on that 12A
Old Aug 15, 2002 | 10:23 PM
David88vert's Avatar
r71's daddy
I believe that I am having a similar problem between 4-5k rpm. Seems to be too rich on the emissions dyno. Just got fuel computer, will hopefully be fixing it next week.
Old Aug 15, 2002 | 10:37 PM
mar3's Avatar
Administrator
Ouch...oh, wow...I guess that's better than getting an infamous DF graphic!! Cold-blooded, maihn...
Old Aug 15, 2002 | 11:32 PM
I am a Jeeper Now.
So you don't feel left out..
Old Aug 16, 2002 | 09:35 AM
Dave-ROR's Avatar
Ok, here's the graph.
Car also has a holley pump (red iirc, not 100% sure, I'll ask the owner) and a good fpr with an accurate gauge that doesn't sit in the car, but plugs into the line for changing fp only when needed.
Old Aug 19, 2002 | 03:03 PM
Dave-ROR's Avatar
to the top.
Old Aug 20, 2002 | 02:12 PM
Dave-ROR's Avatar
ttt any help/suggestions after seeing the graph?
Old Sep 28, 2004 | 07:37 PM
CarlRx7's Avatar
looks like the plugs are missfiring.
this is actually the first dyno of a 12a i have ever seen.
carl.
Old Sep 28, 2004 | 08:39 PM
RUBY7's Avatar
Spark breakdown at high rpm is usually caused by a faulty leading ignitor.
Gosh, I sound like a broken record.
Cheers Sue
BMS2004's Avatar
Frankencar
i'm confused the a/f ratio remains constant yet the power graph is jumpy, weird. wouldn't a missfire cause the a/f to change since there would be some unburned gases causing false readings? Dave do you have EGT's in the car?
Old Sep 28, 2004 | 08:44 PM
Rx7carl's Avatar
Airflow is my life
I agree, the AF should be choppy as well cause of the extra oxy in the exhaust. I dunno wut caused that. Oh and one more thing. Dammit Carl!
AXA
Sep 5, 2015 10:06 AM
