Service Bulletin #F-005/95, Anyone have this?
Old Aug 15, 2002 | 07:15 PM
sunshine's Avatar
Ok, if you guys remember, a few days ago i posted that my car would not run after rebuilding the intake...well with the help of brian from mazdaformance, we figured out that when mazda svitched from the paper main intake gasket to the metal sandwitch...they also put out this Service Bulletin. Does anyone have a copy of this bulletin, or know where i can find it? It has a certain tightening sequence, new tourque specs, and it talks of some sort of "Molybdenum" grease. What the heck is Molybdenum grease???
thanks
(91 n/a)
Old Aug 15, 2002 | 07:40 PM
dre_2ooo's Avatar
Ihave never heard of said bulliten.
Old Aug 15, 2002 | 07:53 PM
RestoTII's Avatar
try here
http://www.alldata.com/recall/make/Mazda/RX7.html
doesn't give much info, but I know another site does, so I'll try to find that and maybe you can find some useful info here
Old Aug 15, 2002 | 07:59 PM
sunshine's Avatar
Here is the fax i got from Brian
Old Aug 15, 2002 | 08:06 PM
RestoTII's Avatar
the Molybdenum grease is probably just plain gasket sealant. without going out to check, I can't be positive, but I'd assume that's about all you'd need to do. Just pick up some Gasket Sealant, remove old gasket, put on new one with some sealant on it, and retorque (being sure to do it in the "correct" sequence)
Old Aug 15, 2002 | 08:07 PM
RestoTII's Avatar
also, for more detailed info, try this
http://www.nhtsa.dot.gov/cars/problems/tsb/index.cfm
Old Aug 15, 2002 | 10:19 PM
Wankel7's Avatar
Haven't we ALL heard this
Yeah, that metal gasket. I have heard of that. Not sure where to get the gasket. would like to have had it
The grease is to asist the metal gasket in staying in place during intake install.
When I got my engine from atkins they had instructions for a metal gasket. Not like I had one.
Email them. www.atkinsrotary.com is the website.
I am sure Dave can give you insight.
And DAMN those TSBs!!!! That is freaking great we can read a list of subjects. Why can't we have access to the text!!!
James
James
Old Aug 15, 2002 | 11:43 PM
COsborne's Avatar
My Custom Title > Your's
I made my gaskets to avoid the $40 charge for them. Theyve been on a few months and havent had any negative results
squirrels
Sep 1, 2024 09:52 AM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
yr6
Oct 4, 2015 12:23 PM
Postman09
Sep 29, 2015 11:23 AM
