Engine start rev ups
Old Aug 15, 2002 | 06:36 PM
Mephis's Avatar
my rx7 will rev up over 8,000rpm when you start it unless you tap the gas , then it idles off at 500rpm and runns like a top (Runs like new) might need spark plugs cause it sounds like it gets choppy
Old Aug 15, 2002 | 06:40 PM
dre_2ooo's Avatar
WTF!? Over 8k?
I suggest you not let ANYONE but YOU drive it... ever.
Sounds like a fucked up AWS system. check the throttle body for stickyness and match spec for EVERY component on there or related to the accelerated warm up system to a FSM or Haynes manual.
Old Aug 15, 2002 | 06:46 PM
Mephis's Avatar
its no big deal it runs good ,i dont know if it hits 8,000 but i dont let it get there , i just got it and replaced the aws cause it would hop along at 50mph reving up and down untill 2nd gear now it runns fine thats the only thing it ever did , but when i 1st got it my car did that thing were it nedded blown out , hit 100mph that took care of alot of problems now a wheel barring went out so im getting another one,as much tuouble as it is its worth all that money
Old Aug 15, 2002 | 07:50 PM
dr0x's Avatar
pei > caek
Ugh, I do believe its susposed to rev to like ~3-4k and then drop off as it warms up... not 8?
Old Aug 15, 2002 | 07:58 PM
dre_2ooo's Avatar
yeah, 3200 is the set warm up stage, then it goes down slowly.
Old Aug 15, 2002 | 09:09 PM
hawaiiangoat's Avatar
My Se7en goes to around 3200rpm and when you tap the gas it goes to 1500rpm for about 5min. then it drops to regular idle.
Old Aug 15, 2002 | 10:12 PM
Josepi's Avatar
Despise Enmity
You guys should seriously start the car in gear with the clutch depressed. It will run up to 2K and idle down from there. 3K on a cold engine only increases wear over time.
Old Aug 16, 2002 | 12:58 AM
rx-7s rock's Avatar
Game of Death
True that. I always start the car in gear, and everytime it only revs to 2k, then drops to 1500, and then to normal idle.
Old Aug 16, 2002 | 12:59 AM
dre_2ooo's Avatar
I always just give it a rev tap... goes down to abut 1300-1550 and settles from there.
Kyo
Apr 13, 2019 09:24 AM
befarrer
Aug 14, 2015 04:18 PM
zuesskroph
Aug 13, 2015 06:05 PM
